Anybody lowered an S-Line on Eibach pro-kit springs
Mazi Mar 15, 2018
  1. Mazi
    Mazi Member
    79
    As per title?
    How much will it lower the car by given the S-Line is already lower?
    This statement from Eibach is a bit concerning.............
    Fitment Notes: All spring measurements are approximate.if you have a sport model such as Sline or Msport. you may not see as much lowering. Without levelling control. Except vehicles with 4WD
  2. Avatar
    Google AdSense Advertisement
  3. B5NUT
    B5NUT Well-Known Member TFSI Owners Group VCDS Map User Audi A6 Audi A3 Audi Avant Owner Group quattro S-line owners group S tronic
    4,627
    1,036
    My C6 was on a Eibach pro kit and it gave about the same ride height as the sline setup.
  4. Mazi
    Mazi Member
    79
    Arch gap looks a bit better to my eyes.
    Is that not an S-Line?
  5. B5NUT
    4,627
    1,036
    It was a 3.0TDi quattro sline which has the FL front-end fitted on it.
    The original shocks & springs on my C6 were well past it, so could have been low due to age related wear, but measuring ride height before and after there was not much difference.
  6. KrisKrk
    KrisKrk A6 C6 4F 2010 LeMans Avant Gold Supporter TDi Audi A6 Audi Avant Owner Group S-line owners group Manual Le Mans Edition
    2,343
    2,246
    Comfort wise, was there any difference?
  7. DPM
    DPM Site Sponsor Site Sponsor
    5,280
    292
    The Eibach Pro springs are a 30mm drop so on the S-line model you'd see a max drop of 15mm but more towards 10mm.
    Damian @ DPM Performance
    Mazi likes this.
  8. B5NUT
    4,627
    1,036
    Very much so, but my old shocks & springs were over 160K miles, the shocks were absolutely destroyed , they had no rebound and should have gone to the bin many miles before that.
  9. dale86
    dale86 Member
    457
    I'm currently looking to lower my 2010 special edition also. I have done a little net searching and found that eibach apparently do a 40/50 mm lowering spring kit but it's only available from larkspeed this sounds much better as if you have a s line le man's or special edition model your not going to hardly see any difference .
