any one running lambo wheels
brownie 25
any of you good folk have or did have lambo reps,i have to order spiggot rings, from what i can see i need 73.1 to 66.6 would i be correct?
brownie 25
Sorry meant to say I'm using hubcentric spacers and the part of the spacer that goes into the wheel is 66.6 but not sure what size outer diameter I need, if that makes any sense
ajax1976
Not really, it's the outer diameter that goes into the wheel. Your spacers should be 57.1 on the inner diameter to sit on cars hub and normally it will be 57.1 on the outer diameter to fit in the wheel, I've never seen spacers that convert hub sizes before. If your wheels are 73.1 then you'll need 73.1 to 57.1 spigots and spacers will be 57.1 so I'm lost as to where you're getting the 66.6 from?
brownie 25
The spacers I got are 66.6 bore with a spigot ring to suit the Audi hub why they are like that I have no idea,I thought they would be a one piece spacer that fits straight onto my hub
ajax1976
Ah!! I wouldn't have been very happy if that's what arrived if I'd bought them but if you're ok with them then yes you'll need 73.1 to 66.6 spigots.
Craig Cull
Site Sponsor
Site Sponsor
I had a set of them, and then another set. They crack for fun so beware. I ended up scrapping 2 sets in the end.
