Best way is to recover a/c from system. Radiator condensor and intercooler all have to be split. Do it right or your going to need to do the job twice. I am there will be sum1 out there done good write up on this. Just do search.
it's possible to leave the a/c radiator on but you have to unbolt them to separate them and maneuver the intercooler out as it's in the middle of the rad pack from memory so they all need to be loose!
It's a PITA though to do it this way - a lot easier to remove the coolant and air con radiators
All done now lads thanks, I chose to take the rad off and leave the a/c rad there it's easier to refill the coolant than the a/c gas. This new Wagner was really seriously snug! The bottom right fan bolt is sitting on the jubilee clip for the right hose and on the left I had to prise the a/c bracket slightly where it meets the rad to slide on the other samco.
I should of done a walk through guide as i couldn't find anything on the net but I didn't really have time to take a load of photos as I only had the weekend to get it done. I suppose most people get a garage to do it as it is quite a large job!
