Any guidance how to remove vandalised door mirror please?
amowolves
Hi All
Unfortunately some scum decided to kick my passenger side door mirror off last night, so its just hanging at the mo. I have ordered a replacement but cant seem to find any info on how to undo the existing one from the door.
anyone shed some light please?
Thanks in advance
Sandra
Administrator
Staff member
Administrator
Audi Main Dealer
Platinum Supporter
Hi All
Thanks in advance
Maybe look at the thread below see if that helps as it looks like the mirror was removed to fit new mirrors.
https://www.audi-sport.net/xf/threads/how-to-remove-and-refit-mirror-caps-on-a6-s6-c7-c7-5.375781/
Mo-S3
You need to remove the interior door panel so you can get to the connectors and remove the 3 bolts behind the upper triangular trim.
There are a few how to on the net on how to remove the 4G door trim.
amowolves
Thankyou.
Yes I followed the below youtube video on how to get the door card off:
*prise off speaker grill and chrome trim around door handle
*remove three screws holding door panel in place
* prise/pull off door panel by popping pins starting at bottom of door card. Pull door card upwards.
Then disconnect mirror loom from module mounted on door and remove the three bolts holding door mirror inplace (under another triangular piece of plastic trim).
I also had to swap over the housing from my old mirror as the new one was a different color. the guide for this is in post above:
Whole job took me about an hour.
be careful not to lose the bolts holding the mirror in place as they can get lost down the inside of the door if not using a magnetic driver.
