Any AMK crankshaft failures?
NZChoppa May 10, 2018
  1. NZChoppa
    NZChoppa New Member
    12
    Hi all,
    Following my AMK engine failing, i was just wondering if any have experienced crankshaft failures in AMK engines??
    Trying to get a feel for whether the tensioner failed, or whether it could have been the crankshaft (snapped). Was moving between 3 and 4th - car was accelerating, but nothing great. Engine was at 140,000 kms.
    cheers, Dan
  2. Avatar
    Google AdSense Advertisement
  3. <tuffty/>
    23,358
    4,947
    No crank failures... plenty of rod failures though
    Only crank failure I have heard of was a guy running 600+hp on e85 fuel...
    What tensioner failed?
  4. NZChoppa
    NZChoppa New Member
    12
    the timing belt tensioner - just trying to get a feel for what might have gone first. initial view is that the tensioner failed - but the timing belt was only done 20,000 kms ago; i was told the tensioner hand been adjusted but it might not have been poorly done.
    i love the car - has been great - but this will cost. just trying to do it in a managed way. if i am going to pay money, i am erring on the side of finding a second BAM engine and doing a full rebuild to minimise as much uncertainty as possible. Is my thinking incorrect?
  5. <tuffty/>
    23,358
    4,947
    Tensioner failure normally results in a head full of bent valves... must have been very unlucky to have locked the engine that much that its snapped the crank...
    Tensioners are self adjusting but the tensioner damper is the point of failure and these often get overlooked on belt changes... these will cause the tensioner roller to go slack and the belt to jump...
    20v engines are pretty resilient but rods and exhaust valves are main failure points...
    In your case you have been very unlucky...
