- Joined
- Jul 10, 2017
- Messages
- 42
- Reaction score
- 20
Hi Guys and Girls, i followed the guide from another retrofit on here:
The car is a B8.5 S4 with front and rear sensors MMI high. All stuff has been purchased from US and came off an S4, apart from camera from Tiguan.
http://www.audi-sport.net/xf/threads/7x8-rear-view-camera-advanced-retrofitted.274069/#post-3099854
I am a little stuck as i have connected everything correctly, i had to do it twice as i had error codes.
I coded the 6C and the camera now has no errors via VCDS.
The problem is when i code the 5F for back up camera and reset MMI the ****** <P> button doesn't do anything. When i put the car in reverse the sensors come up only once and then they vanish, i am able to test the camera as when activated reverse for the first time i can press on the camera bottom left off MMI.
Is this a coding issue as i have scanned the car and there are no fault codes that come up.
All i want is to press the <P> button and be able to see front sensors and rear not to only hear noise.
Any one please
. Beer token will be given.
Thank you,
Any one please
Thank you,
