Another battery issue (or not??)
NyB8
I've spent the last few weeks sorting out a few problems with the B8, but there is one that seem to be eluding me. I have had the Energy Management Active fault present for a while, the full description as below:
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 81
Reset counter: 216
Mileage: 188075 km
Time Indication: 0
Date: 2020.02.09
Time: 11:13:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.50 V
Count: 17
My rear window demist has not been working for a while, and my alarm randomly goes off on average once a month, whilst I have put up with it I couldn't help think that this was related.
A few months ago, I got the right dipped beam warning which seems to randomly come and go and then last week when driving home from work during a heavy downpour, I get the ABS and ESP faults flash up on the dash. I did another scan and a list of errors as long as your arm came up, see below.
VCDS
Self-Diagnosis Log
Monday,28,December,2020,15:10:34:04550
Page 2
VIN: WAUZZZ8K7AA124119 License Plate: BF10VAJ
Address 01: Engine (J623-CAGA) Labels: 03L-906-019-CAG.clb
Part No SW: 03L 906 022 NN HW: 03L 906 019 AL
Component: R4 2,0L EDC H22 9096
Revision: 25H22---
Coding: 12194012232503080000
Shop #: WSC 00385 210 105848
ASAM Dataset: EV_ECM20TDI03L906022NN A02011
ROD: EV_ECM20TDI03L906019AL.rod
VCID: 7EEAEEABB0F78C726D8CB8D-802A
2 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [040] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 196925 km
Date: 2020.12.23
Time: 15:18:43
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [040] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 196925 km
Date: 2020.12.23
Time: 15:18:43
Readiness: 0 0 0 0 0
VCDS
Self-Diagnosis Log
Page 3
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BB HW: 8K0 907 379 BB
Component: ESP8 front H04 0020
Revision: -------- Serial number: --------------
Coding: 160504
Shop #: WSC 06335 000 00000
VCID: 7AE2E2BBACDFA0D251A494D-802E
3 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 184
Mileage: 195560 km
Time Indication: 0
Date: 2020.11.11
Time: 16:01:18
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0026
Hex Value: 0x1203
Hex Value: 0x1694
Hex Value: 0x00FF
00283 - ABS Wheel Speed Sensor; Front Left (G47)
008 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 196925 km
Time Indication: 0
Date: 2020.12.23
Time: 15:18:42
Freeze Frame:
Hex Value: 0x3200
Hex Value: 0x4006
Hex Value: 0x1206
Hex Value: 0x3AB4
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
VCDS
Self-Diagnosis Log
Page 4
Fault Frequency: 1
Reset counter: 212
Mileage: 196925 km
Time Indication: 0
Date: 2020.12.23
Time: 15:18:43
Freeze Frame:
Hex Value: 0x3800
Hex Value: 0x4306
Hex Value: 0x122E
Hex Value: 0x02B3
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0327
Revision: 00002001
Coding: 033200
VCID: 01109557C109F30A106EDB9-8054
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
No fault code found.
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
Component: KLIMA 3 ZONEN H08 0171
Revision: D0000000 Serial number: 01270120101244
Coding: 34240000
VCID: 76FAF68B98C7C4B235FCC0D-8022
VCDS
Self-Diagnosis Log
Page 5
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H25 0380
Revision: 09025001 Serial number: 00000000569500
Coding: 260050914034AF010001000000001D0D001D070804010141000000
VCID: 3A6222BBEC5F60D2112454D-806E
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 150110 H05 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
2 Faults Found:
00979 - Lamp for Low Beam; Right (M31)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 201
Mileage: 195783 km
Time Indication: 0
Date: 2020.11.30
Time: 12:31:00
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 212
Mileage: 196925 km
Time Indication: 0
Date: 2020.12.23
Time: 15:18:00
VCDS
Self-Diagnosis Log
Page 6
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 Q HW: 8K0 919 475
Component: PARKHILFE 4K H06 0070
Revision: 11001001 Serial number: 51231002603322
Coding: 100003
VCID: 47844B4FAFAD0D3A9EAAC51-8012
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H39 0560
Serial number: 003EFD0B9V1B
Coding: 30363435363030303030554A3052384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 419055578189338A50EE1B9-8014
Crash sensor for side airbag; driver side:
Serial number: 6334MSME4F156D0BS
Crash sensor for side airbag; front passenger side:
Serial number: 6344MSME4F557077O
Crash sensor for side airbag; rear; driver side:
Serial number: 6352QSME694B5038N
Crash sensor for side airbag; rear; passenger side:
Serial number: 6362QSME694C1412H
Crash sensor for front airbag; driver side:
Serial number: 63732SME484E09061
Crash sensor for front airbag; front passenger side:
Serial number: 63832SME4C4E12161
VCDS
Self-Diagnosis Log
Page 7
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315JAP000J5
Coding: 000017
VCID: 3D6829A7FD7157EA3406779-8068
Component: E221 - MFL H02 0010
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 212
Mileage: 196925 km
Time Indication: 0
Date: 2020.12.23
Time: 15:18:42
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 980 N HW: 8K0 920 980 N
Component: KOMBIINSTR. H20 0255
Revision: 00200000 Serial number: CIZ224M1A
Coding: 2F0D100002002600010000
Shop #: WSC 06335 123 12345
VCDS
Self-Diagnosis Log
Page 8
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0105
Revision: GB600050 Serial number: 5000G1011782A6
Coding: 00CF07
VCID: 50B660135AE3CA82CF40A65-8004
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0125
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H04 0003
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 81
Reset counter: 216
Mileage: 188075 km
Time Indication: 0
Date: 2020.02.09
Time: 11:13:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.50 V
Count: 17
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 J HW: 8K0 959 793 E
Component: TSG FA H11 0306
Revision: Serial number: 0000102724811
Coding: 011002204001410001
VCDS
Self-Diagnosis Log
Page 9
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0125212975
Coding: 013B0622203904400020023680000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 47: Sound System (J525) Labels: 8T0-035-223-BOC.clb
Part No SW: 8T0 035 223 AR HW: 8T0 035 223 AJ
Component: DSP Prem H19 0320
Revision: 00019001 Serial number: 34835000526602
Coding: 0203010302
VCID: 7EEAEEABB0F78CF26D8CB8D-802A
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 J HW: 8K0 959 792 E
Component: TSG BF H11 0306
Revision: Serial number: 0000102706766
VCID: 469A464BA8A7143265DCD0D-8012
VCDS
Self-Diagnosis Log
Page 10
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000546702
Shop #: WSC 00000 000 00000
VCID: 347E0C83CE3B96A2CB68EA5-8060
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 212
Mileage: 196925 km
Time Indication: 0
Date: 2020.12.23
Time: 15:18:43
Freeze Frame:
Voltage: 14.60 V
Count: 62
Speed: 56.0 km/h
Hex Value: 0x0260
Hex Value: 0x0004
Hex Value: 0x0101
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 A
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06334 000 00000
VCID: 386638B3D2537EC2E750BE5-806C
VCDS
Self-Diagnosis Log
Page 11
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 195 AB HW: 8T2 035 195 AB
Component: Symphony3 DAB H05 0310
Revision: 00000007 Serial number: AUZ5Z4J1171726
Coding: 0503008201028D00035B070000
VCID: 78E6F8B392D3B2C227D0FE5-802C
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
1 Fault Found:
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 126
Mileage: 172502 km
Time Indication: 0
Date: 2019.04.03
Time: 15:15:59
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102732329
Coding: 010002204001210001
VCID: 42925A5B848F281249F40CD-8016
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102732332
VCDS
Self-Diagnosis Log
Page 12
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 335 D HW: 8T0 862 335 D
Component: FSE_256x BT H39 0600
Revision: 00000000 Serial number: 00000005154151
Coding: 0010320
VCID: 3B6C27BFE36555DA0A32591-806E
End-------------------------(Elapsed Time: 03:02)--------------------------
I decided to clear the faults and have been driving about for a couple of days and done a re scan and the only fault to reappear is the energy managment active fault once again.
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 218
Mileage: 197127 km
Time Indication: 0
Date: 2020.12.30
Time: 12:06:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.30 V
Count: 17
I am thinking that this is a battery issue, I got a battery check from the RAC this evening and the mechanic has confirmed that the battery is fine, it's also worth noting that it is the orignal battery!
I have also done a check of the battery and it has returned the following results (attached), I'm at a loss to think what the problem could be, is there any chance it could be a faulty body control module.
Appreciate your help.
What's the voltage running. Should be around 14.5v if you have a multimeter, again you can run with VCDS.
I've read a few similar threads that turned out to a faulty battery harness due to corrosion so battery wasn't charging properly from alternator. If it's the original battery, then that would seem logical place to start and replace. Battery needs to be coded with VCDS so it doesn't age prematurely If replaced. Again when things are starting to light up like a Christmas tree error wise, then a new battery is the way to go. At this time of year it will be worse due to low temperature.
Look at that fault frequency (86), at the top of the readout, so it's been ongoing. My understanding is it needs to be AGM battery if car is start/stop, etc.
A bit more additonal info from the RAC report.
That battery has dropped quite a bit as far as its initial rated CCA, also the car's own interpretation of its present capacity which is 29Ah is very low.
In contrast, my 2011 S4 has 51Ah listed against its original 92Ah rating, the CCA of that battery is still 825Amp EN, it is an AGM and I've prepared for replacing it this February or so as it will be 10years old then and the car's systems thinking its capacity has dropped to 51Ah concerns me, especially if I was taking away overnight etc, though that is that currently an issue with restrictions in movement.
I have already bought a new Bosch AGM S5 013 battery via Costco as they had a 15% discount deal on, and that new battery tests as 975Amps CCA EN against its quoted rating of 850Amps CCA EN.
Reactions: audiwaterpump
12.3V is about 20% left, since 12.84V is 100% new.
Trouble is, if that car has smart charging, it would never end up fully charging the battery, so it would need to be disconnected from the car and connected to a charger then after it was fully charged, left for quite a few hours to settle back to its fully charged stable state, before any post to post open circuit voltage checks were made.
What does that even remotely has to do, with my statement???
You have lost me there, what I said, and I'll try to write it slowly is, if you look at the the battery voltage on a car with a smart charging system, you will never ever measure a high battery voltage, so you handing out what a new battery presumably fully charged would give volts wise and what a well used battery could give voltage wise have no relevance in this thread as the OP was giving us a print out of a VCDS scan and some extra BMS stored stats.
Did that answer your reply?
Edit:- ah, now I've got what this is about, a bit like your contribution to the "brake fittings torque" thread, nice!
Aye, a friend had bought an almost new December 2018 A6 2.0TDI with a good spec and/or trim level and its battery - its battery let him down early 2020 and it was an EFB!!!! His local garage fitted an AGM and I recoded it for him, I too thought that with stop/start and 2.0TDI it should have had an AGM battery from factory, or did that Audi dealership swop batteries before selling it on?
You're talking about something I haven't even said anything about, clearly thinking way out there, with what I might be saying, but you aren't even reading the short line I posted. I'm talking about a battery voltage, and you go on about the smart charging in the car??? Where did I say anything about that, in my voltage post? Nowhere is the answer. Move on, and take the duck with you...
Brilliant, what I expected, jog on there will you.
Offering very little again, keep it up, look out for another thread to add nothing useful to.
Reactions: jdp1962
Can the moderators not ban this jerk? He's been a **** on that lad's Xenon headlight upgrade thread too.
Reactions: jdp1962
If you can keep it, on what I'm actually posting, then we'll be fine. To ban me, for posting a correction about what voltage is fine, and you coming at me, with something completely irrelevant, compared to what I posted, is just.... Talk about being buthurt.
@NyB8 it might help to consider the chronological order. An "Energy Management Active" message does not always indicate a fault. My car gives it ever since I fitted a dashcam with parking mode. This causes a higher quiescent current than the energy management system is expecting. I'd be worried about the ABS codes - possible water ingress?
Exactly how old is the battery anyway?
Date: 2019.04.03 Time: 15:15:59
RADIO 03138 - Input AUX IN 011 - Open Circuit
Date: 2020.02.09 Time: 11:13:00
GATEWAY 03041 - Energy Management Active 000 - - - Intermittent
Date: 2020.11.11 Time: 16:01:18
ABS 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent
Date: 2020.11.30 Time: 12:31:00
CENT ELEC 00979 - Lamp for Low Beam; Right (M31) 012 - Electrical Fault in Circuit - Intermittent
Date: 2020.12.23 Time: 15:18:00
CENT ELEC 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent
Date: 2020.12.23 Time: 15:18:42
ABS 00283 - ABS Wheel Speed Sensor; Front Left (G47) 008 - Implausible Signal - Intermittent - MIL ON
STEERING 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent
Date: 2020.12.23 Time: 15:18:43
ABS 00473 - Control Module for Elect. Park/Hand Brake (J540) 013 - Check DTC Memory - Intermittent
ABS 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent
ENGINE 4698/9 - Function Restriction due to Faults in Other Modules U1113 00 [040] - - Intermittent - Confirmed - Tested Since Memory Clear
DTCs cleared
Date: 2020.12.30 Time: 12:06:00
DTCs cleared
Believe it or not its the original battery! I have a dashcam, but it powers off after about 60 seconds of the ignition being switched off. When I get and dry day. I intend to have a look at the abs sensor for a quick check.
FYI, the alarm went of randomly again this evening !
If you're still on the original battery you need to get that changed asap, otherwise you might be chasing wild geese.
