Annoying Beeps When Ignition On
Monzta Oct 1, 2019
  1. Monzta
    Monzta Member
    56
    Can anyone tell me what these beeps signify? I get them every time I either start the engine or switch the ignition on. Happens every time either with the stereo on or off. Stereo works fine and I've got no warning lights on the dash. I can't find anything in my owner's manual or the stereo manual either. It's a bit annoying and would love to shut them the hell up.
  2. Avatar
    snack-media
    Advertisement
  3. quattrogone
    quattrogone Quattro Back!
    97
    Sorry never heard that one before!
    I'd like mine to stop telling me that a bulb is out when there isn't :pileofpoop:
    Monzta likes this.
  4. stevey83
    stevey83 Member
    134
    Any idea where its coming from? Thats not an Audi noise, so im assuming something aftermarket somewhere.
    Monzta likes this.
  5. Monzta
    Monzta Member
    56
    It's hard to nail down where it's coming from really. The dash area is about as close I can narrow it down to. I'll have a dig around and see if I can find anything aftermarket.
  6. stevey83
    stevey83 Member
    134
    Does you car have an aftermarket phone kit? Check under the steering wheel shroud for thing added. Look for wires etc. Someone added something like that to mine. I stripped it out though.
  7. Monzta
    Monzta Member
    56
    No sign of an aftermarket kit anywhere, none of the usual holes drilled for the holder or any sign of extra aerials added. The factory fit RNS-E SatNav stereo came with a phone option but if one was ever fitted I have no idea. I'll have dig about and see what I can find.
  8. stevey83
    stevey83 Member
    134
    Going by your dash, that radio wasn't factory fit to your car, its to new. If you remove the radio, or at least the fuse to it, does the noise still occur?
  9. Monzta
    Monzta Member
    56
    I was under the impression mine was an SE with the RNS-E stereo and front & rear parking sensors as added extras from the options list.
    I'll pull the fuse and see what happens.:icon thumright:
  10. stevey83
    stevey83 Member
    134
    What plate is your car? Mines a 52 that came with every option including satnav, although it was the rnsd, which is far inferior! Looks like yours has been updated to the newer one at some point
  11. Monzta
    Monzta Member
    56
    Mine's on a 04 plate (registered March 2004).
    I would say that you're right about the stereo being an upgrade, I took out the fuse this morning, turned the ignition and for the first time ... no beeps. So the stereo is the problem.
    VCDS shows the following codes:
    00857 - CD Changer Unit (R41) 004 - No Signal/Communication
    00466 - Control Module for Steering Column Electronics (J527) 008 - Implausible Signal
    So maybe problem stems from these.
  12. Avatar
    snack-media
    Advertisement
  13. Monzta
    Monzta Member
    56
    If I were to replace my standard steering wheel with an identical one but with multi-function buttons for the stereo will it connect with and operate my RNS-E?
    From this ... [​IMG] To this ... [​IMG]
  14. stevey83
    stevey83 Member
    134
    You would need to change the coding, so your car knows you have that steering wheel. Also you need to check if you have that part of the look behind the stereo.
    Monzta likes this.
  15. Monzta
    Monzta Member
    56
    Thanks for that @stevey83 . I'll have to pull the stereo out and see what cables are connected.
    Out of interest, my standard steering wheel is in very nice shape so wondered if I just replaced the airbag part with one that has the stereo buttons whether that would suffice.
  16. stevey83
    stevey83 Member
    134
    Again, i think it depends on what the wiring is there, I threw an airbag out a few months ago with buttons. You could have had it!
  17. Monzta
    Monzta Member
    56
    Oh damn, crappy timing there.
    A breakers near to me has an airbag with stereo buttons at a decent price, I think I'll buy it and see if it works. Gotta be worth a punt for £20.
