Well that was a bloomin busy evening after a day hand digging a trench for a gas main
Nevertheless , the work has paid off .
Wheels washed and tyres scrubbed with TAC Systems Ultra snowfoam shampoo. Dried add cleaned with IPA. Waxed with Angelwax Bilberry Wheel Wax. Further wipe over with IPA.
Gtechniq C5 applied. Not sure if it was the colour of the wheels or the lighting conditions but found it hard to see where is applied C5. Luckily I'm a methodical type so I'm confident it applied well enough. Have a enough left over to coat the tail pipes on the A3 at some point . I do think the lint free applicators were a little meager. Would buy more next time around . Also glad I went with the 30ml bottle . Very light wipe over with an MF to even out by the C5 and that was job done . Only time will give the overall verdict I guess .
Then onto the tyres. 3 coats of TAC systems tyre dressing........ Courtesy of
@Tashfeen . Thanks Tash
Initial thoughts. Love it
I couldn't apply it using James method per se . Tried putting some drops on the tyre wall and leaving it a while but it just kept trying to run . Could be the shape of the tyre or me being clumsy
So this is the way I applied it .
Applied a thin layer all the way around the tyre. Moved onto the next tyre and did the same . Kind of like applying a primer or undercoat layer if you like. Left for about 15 minutes. Then generously applied a good amount at 10 minute intervals around the tyre wall as if it were a clock face . Left another 5 minutes and then spread around the tyre wall untill even and smooth. After 20 minutes repeated the process. Did this for all the tyres.
I've got to say a little goes a long way, barely used much from the bottle , so can see how tash got so many coats from the amount he'd used previously .
The overall look is really good in my opinion , obviously durability add longevity only time will tell . Sat in the hallway they look bloomin good. The wheels won't go on till about 6-7pm tomorrow , so plenty of cutting time for all products . Hopefully the TAC doesnt sling .
Need some new foam applicators now though
Looking forward to tomorrow and putting the new boots on the A3 .
Sent from my Nokia 8 using Tapatalk
