Hi All,
A bit of background to this, so ill try to keep it short and concise.
Im in Australia. The car is a 2015 4M Q7. I have owne it for about 5 months, and it has an extended warranty from an indepentant warranty company.
Last week I went to start the car to go to work in the morning, and had three faults come up on the dash.
1) Parking Brake Fault. Please contact workshop.
2) Start/Stop system fault. Function Unavailable. Please contact workshop.
3) Hold Assist Unavailable.
Did a VCDS scan on it myself, and tried a simple reset, with no luck. I rang the warranty company to lodge a claim. They sent me to one of their mechanics who is apparently "Eurpoean Certified" (LOL). On picking the car up from them, they advised they were unable to diagnose the issue, but suspected a faulty battery.
After I drove off and was halfway home, i realised i had a number of ADDITIONAL faults on the dash that weren't there before. I didnt really think much of it, suspecting that if indeed the battery was faulty, it's not out of the question that other faults could come up. The additional faults were:
4) Audi pre sense: emergency braking system off.
5) Distance Warning fault. Please contact workshop.
Additionally when I try to engage cruise control, I get a fault with that as well. These new faults seem related to the distance sensors (mental note for later).
So, furstrated with the situation (and asfter getting into a heated discussion with the Warranty Company), I decided to do a little more troubleshooting myself. I did a fully scan looking for anything obvious. The first thing that stood out to me was a fault with the park brake switch.
292608 - Switch for Electric Parking Brake
C100C 01 [047] - Electrical Failure
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Mileage: 153907 km
Date: 2022.08.26
Time: 07:12:25
So - I picked up myself a new switch and swapped it over and did a DTC reset. Hey presto, the faults relating to Park brake fault, Start/Stop system and Hold Assist all went away.
So - what i left with now is wat appears to be a handful of issues, all potentially related to the distance sensors on the front of the car. The front bar has not been off, and while i have had the car in my possession, have not hit anything etc. The unknown is what this shoddy workshop could potentially have done while they had the car (ive tried having that conversation with them = dead end).
What im now trying to understand is, is there any way i can reset / test / adjust the distance sensors myself. I cam across a thread relating to an older Audi which had some good info about determining if the alignment has fallen outside of tolerance (+/- .8 degrees), and to the best of my knowledge, they have not.
I've used the security code 20103 for both modules "Adaptive Cruise 2" and "Auto Dist", but an unable to find any way to reset the distance sensors.
What im trying to do is avoid having to take the car to Audi and get charged hundreds and hundreds of dollars, if there is a way I can do this myself.
So - looking for some guidance here folks. Does anyone have any insight as to how i might be able to move past this issue myself?. I have the car booked in with Audi for tomorrow, so if im able to resolve it myself, i can cancel my booking.
Sunday,28,August,2022,07:45:37:10040
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WAUZZZ4M0GD License Plate: XXXXX
Mileage: 154055km-95725mi Repair Order:
Chassis Type: 4M-AU73 (4M2)
Scan: 01 02 03 06 08 09 13 15 16 17 19 29 36 39 3C 42 44 46 47 50
52 5F 65 69 6C 6D 81 82 8B A5 AC BB BC CF D6 D7
VIN: WAUZZZ4M0GD006914 Mileage: 154055km-95725miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
29-Left Light -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
39-Right Light -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
50-Seat Adj. 3rd row -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
82-Head Up Display -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
AC-Reductant Control -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CRTC) Labels: Redir Fail!
Part No SW: 4M0 907 401 HW: 059 907 309 B
Component: 3.0TDI EDC17 H45 0010
Revision: 91H45--- CVN: BF723FED4F8B6DFB92F1EF3C
Coding: 2A2A40320566050334380000000000000000000000000000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_ECM30TDI0114M0907401 001014
ROD: EV_ECM30TDI0114M0907401.rod
VCID: 6695B86CE8E5BEBB553-8032
VINID: 9D196AAAA11D01750000624110F6223F9C
1 Fault Found:
17156 - Databus
U1123 00 [039] - Received Error Message
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 154055 km
Date: 2022.08.28
Time: 07:41:30
Engine RPM: 828.50 /min
Normed load value: 27.8 %
Vehicle speed: 0 km/h
Coolant temperature: 71 °C
Intake air temperature: 14 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.540 V
Unlearning counter according OBD: 40
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4M0 927 158 J HW: 0D5 927 156 H
Component: 0D5 30TDIRdW H03 1016
Revision: --H03--- CVN: D4683A9B
Coding: 100000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011_AU49.rod
VCID: 3B233918C3E7D353DAD-806E
No fault code found.
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-PRE-V1.clb
Part No SW: 4M0 907 379 K HW: 4M0 907 379 K
Component: ESP9 Premium H08 0521
CVN: DB04DF19
Coding: 289830B230A20A9C96A75892008112A2E6A6DA140C0C50691A00484567655B
Shop #: WSC 52333 002 1048576
ASAM Dataset: EV_ESP9BOSCHAU736 011006
ROD: EV_ESP9BOSCHAU736_AU73.rod
VCID: 3FDB4D08D7FFCF73F65-806A
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M0 959 760 HW: 4M0 959 760
Component: MEM-BFS 008 0014
Serial number: 00000153913953
Coding: 002010000000B0010000210101010000000000000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
ROD: EV_SCMPasseSideCONTIAU736.rod
VCID: 75B7EF20A5434523EC9-8020
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 4M0 820 043 R HW: 4M0 820 043 R
Component: Klima Zone 2 H52 0112
Coding: 661801BC5140050910000180000000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
ROD: EV_AirCondiFrontBHTCAU736.rod
VCID: 34311224EEB91C2B1B7-8060
Fresh air blower control module (front):
Subsystem 1 - Part No SW: 4M2 820 021 HW: 4M2 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000000426497
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4G0 907 658 B HW: 4G0 907 658 B
Component: Humidity_Sens H01 0003
Serial number: E318CEA7000000000001
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 G HW: 8W0 907 063 G
Component: BCM1 MLBevo H12 0215
Coding: 07501943C12900CD010D06115B3F08F913033100800000000000000060001C810A4502AB22B70A
ASAM Dataset: EV_BCM1BOSCHAU736 014003
ROD: EV_BCM1BOSCHAU736_014.rod
Wiper motor control module:
Subsystem 1 - Part No SW: 4M2 955 119 A HW: 4H1 955 119 C Labels: 1KX-955-119.CLB
Component: WWS536 141126 042 0792
Serial number: 141201120328
Coding: 1BC7F7
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 20345251
Coding: 02006E
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 P HW: 4M0 941 531 P
Component: E1 - LDS H05 0007
Serial number: 30 05 2015 00026621
Automatic dimming interior mirror:
Subsystem 4 - Part No SW: 4M0 857 511 A HW: 4M0 857 511 A
Component: Y7_Innenspieg H08 0002
Serial number: GX1CE126051511520292
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 4M0 947 135 BA HW: 4M0 947 135
Component: J528-Dachele H13 0080
Serial number: Q00014515
Control head for driving and comfort functions:
Subsystem 6 - Part No SW: 4M0 925 301 B HW: 4M0 925 301 B
Component: SL-Q7NF/AU736 H09 0006
Serial number: 00000000000000005699
1 Fault Found:
65560 - Terminal 30-3
U1413 00 [009] - Open circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 14
Mileage: 154055 km
Date: 2022.08.28
Time: 07:42:31
average_Voltage_terminals: 14.60 V
Outside air temperature sensor-Resistance: 491.52 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 11.00 °C
interior_temperature: 15310.00 °C
Vehicle speed: 0.00 km/h
Terminal activation-Terminal 75 status: On
Terminal activation-Terminal 15 status signal: On
Terminal activation-Terminal 15 via CAN: On
Terminal activation-Term 75: qualification: OFF
Address 13: Auto Dist. Reg (J428) Labels:* Redir Fail!
Part No SW: 4M0 907 561 C HW: 4M0 907 561
Component: LRR4 H08 0160
Coding: 3476E7FB58FFEC08949880A4
ASAM Dataset: EV_ACCBOSCHAU736 001016
ROD: EV_ACCBOSCHAU736.rod
VCID: 30391E341AA1200B7FF-8064
1 Fault Found:
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_ALIGNMENT_NOT_OK]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 14
Mileage: 154044 km
Date: 2022.08.27
Time: 14:35:48
Control Module temperature: 35 °C
Voltage terminal 15: 12.1 V
Velocity_vehicle_reference: 0.00 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
Status_ACC_System: ACC_irreversible error
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 4M0 959 655 HW: 4M0 959 655
Component: Airbag10.44 H50 0084
Serial number: 003L10007B22
Coding: AAFCF0D80C80000098F65000C08C00000000
Shop #: WSC 28273 002 1048576
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: EV_AirbaAU10BPAAU736_005.rod
VCID: 78A9E614B251384BF7F-802C
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 4M0857705D0154P00439
Coding: 88001B
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 4M0857706D0138P00231
Coding: 88001B
Crash sensor for side airbag: driver side:
Subsystem 3 - Part No SW: ----------- HW: 442 061 006 15
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y00B3193B850A2F5
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 4 - Part No SW: ----------- HW: 442 061 006 15
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y00B3193B850A26/
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 5 - Part No SW: ----------- HW: 442 0B2 705 15
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700C31A234B6721%
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 205 15
Component: SideSensor_Pr 1C7 0148
Serial number: 35277001829352E8E8FR
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 7 - Part No SW: ----------- HW: 442 0C0 506 15
Component: FrontSensor_D 1C5 014A
Serial number: 3557500B9199EA06F28X
Coding: 2D2D2D
Crash sensor for front airbag: front passenger side:
Subsystem 8 - Part No SW: ----------- HW: 442 0C0 506 15
Component: FrontSensor_P 1C5 014A
Serial number: 3567500B9199EA03828O
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 9 - Part No SW: ----------- HW: 442 0C2 605 15
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500B31B21F76F28D
Coding: 2D2D2D
Driver's side crash data pedestrian protection 2:
Subsystem 10 - Part No SW: ----------- HW: 442 420 906 15
Component: PedPSensor_D2 21E 0887
Serial number: I0M8U00C3193B85390ER
Coding: 2D2D2D
Passenger's side crash data pedestrian protection 2:
Subsystem 11 - Part No SW: ----------- HW: 442 420 906 15
Component: PedPSensor_P2 21E 0887
Serial number: I0N8U00C3193B85491FV
Coding: 2D2D2D
Central crash sensor X/Y:
Subsystem 12 - Part No SW: ----------- HW: 410 201 505 15
Component: CentrSensorXY 1C8 0108
Serial number: I0O7800C51A580C1D230
Coding: 2D2D2D
4 Faults Found:
1060613 - Databus
U1123 00 [009] - Received Error Message
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Objektstatus]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 14
Mileage: 154044 km
Date: 2022.08.27
Time: 15:08:10
1060614 - Databus
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 14
Mileage: 154044 km
Date: 2022.08.27
Time: 15:08:10
1060615 - Databus
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_v_rel]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 14
Mileage: 154044 km
Date: 2022.08.27
Time: 15:08:10
1060617 - Databus
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 14
Mileage: 154044 km
Date: 2022.08.27
Time: 15:08:10
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 HL HW: 4M0 907 129 HL
Component: Lenks.Modul H11 0008
ASAM Dataset: EV_SMLSKLOAU736 006008
ROD: EV_SMLSKLOAU736_006.rod
VCID: 015F8BF0E18B7983C01-8054
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4M0 920 790 HW: 4M0 920 790
Component: FBenRDW H12 0378
Coding: 240D00C06C9C000801A3ED601000601000000000
ASAM Dataset: EV_DashBoardAU736 001027
ROD: EV_DashBoardAU736_AU73.rod
VCID: 6C81CA44F60984EB037-8038
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4M2 907 468 A HW: 4M2 907 468 A
Component: Gateway H13 4079
Revision: 3C010050 Serial number: 5043C027415513
Coding: 0301000100008F407F000000005900305C120007108000000100000000000000
GVL: 01583C0808040000C0FCC8000002C800000C2000000000000000000000000000
ASAM Dataset: EV_GatewCONTIAU736 002040
ROD: EV_GatewCONTIAU736_002_AU73.rod
VCID: 3635282CF8C50E3B253-8062
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 4M0 951 523 HW: 4M0 951 523
Component: J453 MFL H06 0002
Serial number: 20150512145359 RD291
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 8S0 915 181 HW: 8S0 915 181
Component: J367-BDMHella H10 9041
Serial number: 4009796803
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 B HW: 4M0 907 397 B
Component: LCM_MLBevoH05 0011
ASAM Dataset: EV_LCMLeftHELLAAU736 001006
ROD: EV_LCMLeftHELLAAU736_VW48.rod
Address 36: Seat Mem. Drvr (J136) Labels:* None
Component: MEM-FS 008 0014
Serial number: 00000153914867
Coding: 00381B000000B0010000210101010000000000000000000000000000000000
ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
ROD: EV_SCMDriveSideCONTIAU736_006.rod
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
ASAM Dataset: EV_LCMRightHELLAAU736 001006
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 HW: 4M0 907 566
Component: MRR1Rear H13 0161
Revision: --------
Coding: 4EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001015
ROD: EV_RearRadarS1BoschAU736.rod
VCID: 72BDD43CD42D521BC9B-8026
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 G HW: 4M0 959 793 C
Component: TSG FS 009 0052
Serial number: 0000153288311
Coding: 005C9B005E010080000130B0
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
VCID: 42DD44FCA40DA29B99B-8016
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 4M0 909 144 G HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H17 0004
Serial number: 0000868943
Coding: B0110101000101
ASAM Dataset: EV_EPSVWBSAU736 008020
ROD: EV_EPSVWBSAU736_008.rod
VCID: 33331138EBB71B1302D-8066
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 AD HW: 4M0 907 064 D
Component: BCM2 MLBevo 015 0307
Coding: 01351E00400000C0630980000E00580203034000004F02502F0400000504803F001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 010010
ROD: EV_BCM2HellaAU736_010_AU73.rod
VCID: 7EA5F00C9075067BBD3-802A
ID - sensor:
Subsystem 1 - Part No SW: 4M0 959 754 AJ HW: 4M0 959 754 AJ
Component: ID-Geber H32 0102
Serial number: 3615000120379003
Coding: 000000
Rear lid opener control module:
Subsystem 2 - Part No SW: 3AA 962 243 F HW: 3AA 962 243 F
Component: GEB.F.Heckoef H16 0815
Serial number: 94007413
Address 47: Sound System (J525) Labels:* None
Part No SW: 4M0 035 223 A HW: 4M0 035 223
Component: MIB2_amp_PD H02 0420
Serial number: 00000000004075
Coding: 01350608008AF53AAF0000010000
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
VCID: 211FEB70414B9983E01-8074
Address 50: Seat Adj. 3rd row (J857) Labels:* None
Part No SW: 4M0 959 760 G HW: 4M0 959 760 G
Component: MEM-SR3 008 0014
Serial number: 00000153885961
Coding: FF201020F1000000000F000000000900000021210900000000000000440000
ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
VCID: 3C213A04C6E9D46BD37-8068
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 4M0 959 792 D HW: 4M0 959 792 C
Component: TSG BFS 009 0036
Serial number: 0000154058530
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
VCID: 3E25300CD0F5C67BFD3-806A
Address 5F: Information Electr. (J794) Labels:* 4M0-035-MIB-HGH2.clb
Part No SW: 4M0 035 041 K HW: 4M0 035 041
Component: MU-P-LND-RW 041 1421
Serial number: A371F0FB000130
Coding: 013706080000000013511102000A00102F001BE6017001049E
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 290FF350397B51C3B81-807C
Data carrier:
Subsystem 1 - Part No SW: V03 959 801 FL HW: -----------
Component: ROW 2015 --- 0039
Serial number: --------------------
Multimedia System 1:
Subsystem 2 - Part No SW: 4M0 919 605 HW: 4M0 919 605
Component: AU536_DU_HIGH H43 0008
Serial number: AUZ8Z9FJ4009FM
Multimedia system control head:
Subsystem 3 - Part No SW: 4M0 919 615 H HW: 4M0 919 615 D
Component: ControlUnit_P H14 0209
Serial number: 04061500000000000079
Compact disc data bank:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 4006
Address 65: Tire Pressure (J502) Labels: 4M0-907-273.clb
Part No SW: 4M0 907 273 HW: 4M0 907 273
Component: RDKHUFAU736 H03 0009
Serial number: 30000000001699
ASAM Dataset: EV_RDKHUFAU736 002006
ROD: EV_RDKHUFAU736_AU37.rod
VCID: 6D87C740CD138DE3149-8038
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 4M0 907 383 F HW: 4M0 907 383 B
Component: Anhaenger H27 0253
Revision: 9A001003 Serial number: 0528080666
Coding: 0310000202000000
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW26.rod
VCID: 35372F20E5C305232C9-8060
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4M0 907 428 D HW: 4M0 907 428
Component: Areaview 2 H11 0311
Serial number: C854606JG000315
Coding: 02350601BF0FA10008404084
Shop #: WSC 50803 002 104857
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 4M0 959 107 HW: 4M0 959 107
Component: HDSG-Modul H12 0143
Revision: -------- Serial number: 30042135600000
Coding: 00F0
ASAM Dataset: EV_DeckLidCONTIAU736 001010
ROD: EV_DeckLidCONTIAU736_VW37.rod
VCID: 70B9DE34DA21600B3FF-8024
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4M2 713 041 D HW: 4M2 713 041 D
Component: GSM-LL H07 0066
Revision: 0L0D5012 Serial number: 20150512000261
ASAM Dataset: EV_GSMWaehlZFAU736 001013
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 270BF5682F6F67B3AE5-8072
Address 82: Head Up Display (J898) Labels:* None
Part No SW: 4M0 919 617 A HW: 4M0 919 617 A
Component: HeadUpDisplay H25 1507
Coding: 4F00C0
ASAM Dataset: EV_HudNSEIKAU736 001012
ROD: EV_HudNSEIKAU736_AU73.rod
Address 8B: Adaptive Cruise 2 (J850) Labels: 4M0-907-541.clb
Part No SW: 4M0 907 541 C HW: 4M0 907 541
ASAM Dataset: EV_ACC2BOSCHAU736 001016
ROD: EV_ACC2BOSCHAU49X_001.rod
VCID: 2E05004C009536FB6D3-807A
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 4M0 907 217 D HW: 4M0 907 217 A
Component: BVS H11 0042
Coding: 0407030600000401024023A7CD0000FCB0F0C020E280
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026
ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
VCID: 2F3B1D48079F3FF3665-807A
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 HW: 4M0 907 355
Component: SCR-Stg-G3H10 0003
ASAM Dataset: EV_RDCMINERGAU736 005009
ROD: EV_RDCMINERGAU736_AU49.rod
VCID: 6E85C04CC01576FB2D3-803A
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 4M0 959 795 D HW: 4M0 959 795 C
Component: TSG HFS 009 0036
Serial number: 0000155358588
Coding: 004C990000010080000030A0
ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005
ROD: EV_DCU2RearDriveMAXHCONT_AU49.rod
VCID: 41DF4BF0A10BB983801-8014
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 009 0036
Serial number: 0000155358422
ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005
ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 HW: 4M0 907 590
Revision: --------
Coding: 4EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001015
ROD: EV_RearRadarS2BoschAU736.rod
VCID: 6FBBDD48C71F7FF3265-803A
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-592.clb
Part No SW: 7PP 941 592 CA HW: 7PP 941 592 C
Component: LED1L H09 2002
ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
ROD: EV_LEDModLeftMELCOAU736_AU73.rod
VCID: 196FC390691BC143281-804C
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-592.clb
Component: LED1R H09 2002
ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----------(Elapsed Time: 02:26, VBatt start/end: 14.7V/14.8V)-----------
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 153907 km
Date: 2022.08.26
Time: 07:12:25
www.Ross-Tech.com
1 Fault Found:
17156 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 154055 km
Date: 2022.08.28
Time: 07:41:30
Coding: 100000
CVN: DB04DF19
Coding: 1BC7F7
Coding: 02006E
Light switch:
Coding: 210000
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 14
Mileage: 154055 km
Date: 2022.08.28
Time: 07:42:31
1 Fault Found:
C1103 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 14
Mileage: 154044 km
Date: 2022.08.27
Time: 14:35:48
Coding: 88001B
Coding: 88001B
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
4 Faults Found:
1060613 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 14
Mileage: 154044 km
Date: 2022.08.27
Time: 15:08:10
1060614 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 14
Mileage: 154044 km
Date: 2022.08.27
Time: 15:08:10
1060615 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 14
Mileage: 154044 km
Date: 2022.08.27
Time: 15:08:10
1060617 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 14
Mileage: 154044 km
Date: 2022.08.27
Time: 15:08:10
Revision: --------
Coding: 4EC002
ID - sensor:
Coding: 000000
Data carrier:
Coding: 00F0
Coding: 4F00C0
Revision: --------
Coding: 4EC002
