Going from 2.0 to 3.0 I knew fuel economy will be lowered but 22 mpg is too low.
Friday,17,February,2017,15:15:29:25423
VCDS Version: Release 17.1.2 Running on Windows 10 x86
www.Ross-Tech.com
Address 01: Engine Labels: 059-907-401-V2.clb
Control Module Part Number: 4G0 907 401 F HW: 4G0 907 401
Component and/or Version: BSR v1 OY12SV X37 0004
Software Coding: 0A254012052601020000
Work Shop Code: WSC 01286 386 08256
ASAM Dataset: EV_ECM30TDI0114G0907401F 001004 (AU57)
ROD: EV_ECM30TDI0114G0907401F.rod
VCID: 2643A6A259844271B9-8072
1 Fault Found:
7036 - Thermostat for Mapped Engine Cooling (F265)
P0597 00 [047] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 87126 km
Date: 2017.02.17
Time: 22:41:08
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 81 °C
Intake air temperature: 28 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 11.920 V
Unlearning counter according OBD: 40
Accelerator pedal travel: 0.00 %
Coolant temperature at radiator outlet: actual value: 19.7 °C
Heat delivery temperature in cooling system: -273.1 °C
Outside air temperature: 7.5 °C
Fuel consumption: 0.00 l/h
Fuel temperature: 50.9 °C
Engine oil temperature: 77.2 °C
Readiness: 0000 0000
What was the cause of poor consumption? Oil filter, the housing?
Sent from my HTC One_M8 using Tapatalk
Yes it showed fault code under engine module. I posted scan earlier. Initially I thought it's egr thermostat as there was no CEL on dash and temperature sits in 90.did that show up on a VCDS scan or a bit of tinkering around?
