Alarm 3 beeps ignition on - how to re-set ?
AGB-S3 May 17, 2018
  1. AGB-S3
    AGB-S3 Active Member
    331
    26
    Had to fit a new battery , brand new yasa batter seemingly fell to bits after 2 years , but , the alarm seems need re-setting ?
    Cars running and the doors lock etc. but , Im getting 3 beeps from what seems to be a sounder inside the car , somewhere , near side rear ..when the ignition is turned on
    Is there a re set sequence or something ive missed out ?
    Tnx-Graham
  2. Avatar
    Google AdSense Advertisement
  3. Tj 0785
    Tj 0785 Well-Known Member Silver Supporter VCDS Map User Bronze Supporter Audi S3
    2,650
    695
    Usually that means the batteries inside the alarm siren are on the way out and need replacing
  4. AGB-S3
    331
    26
    Ah , ok, just a coincidence , thought something was hung up ............next question
    where and what are the alarm batteries ?
    Tnx-G
  5. <tuffty/>
    23,369
    4,958
  6. hydro s3
    hydro s3 S3 amk Team Ming Blue Audi S3
    890
    233
    43
    The alarm.is in the back passenger wheel arch. It will be below the CD changer. You will need to take of the boot trim and the side trim so you can get to the screws holding the CD changer in and the sub will also need taken out. It is then located below the back light cluster on a bracket bolted to the body work. You will then have to open up the alarm siren and replace the batterys not sure on what tool you need some kind of cutter to open it up.
    Hope this helps and if you need anything else post it up and some one will help.
  7. AGB-S3
    331
    26
    I don't think I have a CD changer , the wheel arch storage areas , contain the bose sound amplifiers and a lot of multi pin plugs and cables ...even changing the stop/indicator bulb is a only a job for Lilliputians ...
    Tnx -
  8. Tj 0785
    2,650
    695
    It’s under all that right at the bottom I’ve had a new alarm siren for a year but seems to be a pain of a job so it’s still just sat there. But with holiday nearly out the way and stuff round the house nearly all sorted the s3 can take priority again
