Aircon Pulley Measurements
Dibs_h
Member
Does anyone have ready access to an a\c compressor - or the pulley more importantly?
I would greatly appreciate the measurements between the centres of the 3 holes around the centre nut\head\shaft. The approx diameter of those holes would be great too. I've seen tools that are used with an impact driver that undo the drive plate, that have 3 prongs that engage with those holes.
I'm hoping with the measurements and an hr or so in the workshop - I can bodge something up that should work. But this grand idea came after the unsuccessful attempt to remove the pulley on the pump and putting everything back.
Dibs
Managed to blag a few mins at a breakers yard with another pump (Denso 6SEU14C) and had a set of verniers in my pocket. :)
The 3 holes are 23.5mm pin centre to pin centre. And the holes are 6mm in diameter.
Thought to post up the info in case it comes in handy fo someone.
My mate with an engineering shop is going to knock me up the adapter gratis. So hopefully have the damn thing off at some point soon.
Cheers.
Dibs
