Facelift Aircon fault...
T
T-800
Guest
Aircon decided to go on strike today
Anyway when I got in I scanned the car and had a high pressure sensor fault (no signal)
Cleared the fault, no joy....
Unplugged the sensor to see if the fault nature changed, still exactly same fault
Conclusion
New sensor required part number 4H0959126B.
Will get one tomorrow and fit.
Good job I got the pano roof
T
T-800
Guest
Yeah same thing I imagine
Ain't going into Audi...…..sensor is cheap enough and there's a Schrader valve behind it so refrigerant cannot escape.
penetrator
Conclusion
Is it tuned?
T
T-800
Guest
All fixed.......
Dodgy wiring.....
Had the air con re-gassed also
460g extracted and the correct 530g put back in.
T
T-800
Guest
I thought it was a dodgy sensor?
Turns out it wasn't......
The wiring issue made it look like it was.
The High pressure sensor is well known for failing on Audi's though.
Reactions: D0C
