Absolutely.If you have an airbag warning come up this is a safety issue. I would think that you should take it to the dealers/garage asap.
Agree don’t mess with safety systems.
Hi mate just finished night shift the error clears straight away with carista for about 4/5 days and comes back just thought it might have been a loose plugAbsolutely.
Those error codes relate to the supplemental restraint system. I had a similar - and it was similar, not identical - error in my daughter's 8P; an airbag warning light and an error that would not clear despite several attempts. That error was caused by an unrepairable fault in the airbag control module, resulting in a very large and unavoidable bill.
You can't just pick one of those modules up from the local scrappie and Scotchlok it in on a Sunday afternoon over a mug of tea.
Sometimes sh*t happens and you have to cough hard and pay up. Maybe more pertinently, I learned that while the airbag warning light is on, the airbags won't work if a tree runs out into the road and hits you.
Now I'm not saying that this is what's wrong with your car, because I wouldn't be that presumptuous.
What I would do, though, is suggest that you get this checked out properly.
I was a bit reluctant to put what I did earlier because describing a similar occurrence isn't always terribly helpful...Hi mate just finished night shift the error clears straight away with carista for about 4/5 days and comes back just thought it might have been a loose plug
Cheers my old 8p was fault freeI was a bit reluctant to put what I did earlier because describing a similar occurrence isn't always terribly helpful...
Having said that, our warning light reappeared after clearing the error within less than a minute of turning the ignition on again, every single time.
I tried the connector under the seat as well, more in hope than with any real expectation of it saving us the eight hundred-odd quid it ended up costing.
That kind of good luck always seems to follow other people around, not me.
Mind you, having seen our girl's bottom lip begin to tremble when they told us how much it would be, the dealership did waive their sixty quid diagnostic charge, which was nice of them.
We had no choice but to cough; as mentioned elsewhere this was a dealership-only job, and much as they'd like to have helped, our usual blokes just couldn't do it.
And the car's a 59 plate and was yonks out of warranty.
Still, in the eight years she's had it, it's literally the only thing that's ever failed. It's still on all its original bulbs, and we've never changed either key fob battery.
They don't make them like they used to.
Good luck!
