Every morning I start my car and the airbage light goes out but comes on a few seconds later. I then stop the engine and use an airbag resetter tool to put the light out (sometimes takes a couple of attempts). Thereafter the airbag light works fine all day, but the next morning I have to go through the same procedure. recently when the car was in getting a new diesel pump (£785!!) and two new rear springs, I asked the garage to sort the airbag problem. They ran a fault code check which said there was a fault with the ECU and they couldn't switch the light off, upon which I plugged my wee box in and switched it off. It appears to me that the fault probably isn't in the ECU as it works OK once I fix it but the fault reappears overnight. Having spent about twice the value of the car in repairs in the last year, I am loath to scrap it for this one last problem, but I can't really sell it although I can get an MoT if I switch the light off in the morning before it goes for its test. Can anyone shed any light on what the most likely problem is? Also, to get a peek at the ECU I think I need to remove the ashtray - where do you press to release it? Does the climate control panel have to come out first, and if so how do you do that? I have a feeling I have already done that in the past but can't remember what holds it all in.
I think I'll ask them to re-run the fault code check and get a full list of the actual codes as that might give a further clue. i just don't think the ECU is the problem when it can be persuaded to work fine fairly simply, but I can't figure out what might change overnight to stop it working other than maybe some sort of voltage drop or condensation forming.
