You've probably pulled the wires under the front seats while you were doing the rears, make sure all the plugs under the seats are pushed together properly, then re-set the light with a code reader.
Scan it for fault codes would be the obvious one as you need to use something like VCDS to clear an airbag light anyway as they don't switch off themselves...
My money is on the seatbelt tensioners (igniters I think they would come up as in a fault scan)
