  2. Dismiss Notice
Air con removal
jezzy Apr 30, 2013
  1. jezzy
    jezzy Registered User
    759
    19
    Hello
    My v2 cracked the other day, so i removed and is off at the welders.
    I needed to fit my new clutch, poly bush the front end and fit my brembos.
    So i decided to remove the front end and do the clutch and fit the v2 with the engine out of the car.
    Got the front end (bumper and associated parts removed) now im stuck.
    I forgot all about the aircon pipe work to the front radiator.
    Any ideas where to disconnect the pipe work at, so the front comes away as one ?
    Anything i should be aware of and avoid?
    Any info much appreciated
    Regards
  2. Avatar
    snack-media
    Advertisement
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,099
    738
    To do it right you really need the gas capturing, if it is empty just disconnect the pipe work, watch your eyes when undoing as it is not nice stuff..
  4. Scullies
    Scullies Registered User
    1,541
    660
    When I remove the front end, I undo the aircon lines that go into the condenser. There is an inlet on one side and outlet on the other.
  5. jezzy
    759
    19
    Thanks for the info much appreciated.
    My aircon still has gas in the system.
    hmm dilemmas
