Gm95
Hi guys,
First off, sorry if the information for this is already on a different thread. I was really expecting to find it straight away but after a search I couldn't really see anything.
I'm just looking for a bit of advice. I have an '05 A3 2.0 TFSI and with the lovely weather we have been having recently, the climate control has actually been trying to use Air Con. However, no matter what I set it to, the vents just blew warm air. I turned Auto off and just put the fans on full, temp set to 'Lo' and drove all the way home from work with it like it to see if it would start to go cooler at any point but no luck.
When I turned 'Econ' on which I believe is meant to deactivate Air con, the vents started blowing slightly cooler but not cold. I imagine this is just because it is then just taking air from outside and acting as a fan?
My first thought was that I should just get it re-gassed as there's offers on that left, right and centre around me at the moment but I've been told by a friend in the know that around my year of car, vag changed the A/C compressor and they're prone to fail, get stuck, break a part in the pulley so that it free-wheels and sends metal shavings around the loop. Therefore I'd be looking at a full a/c rebuild costing up to a grand to get it working again?
My question is if anyone can confirm this? Has anyone had my experience and solved it with just a simple re-gas? And lastly if the above is the case, is there anyway I can test to check if the compressor has actually seized.
