  2. Dismiss Notice
Air Con Delay before becoming cool - Fault Code attached?
Avus Sportback Jul 25, 2012
  1. Avus Sportback
    Avus Sportback Member
    115
    Hi Guys,
    Just noticed over the last few days that the Air Con takes about 10 min before it finally comes on and blows Freezing, car is a 2009 TDI BE with it in Auto mode (Temp on Low) and AC turned on with Recirc on Auto, it doesn't sound to me that its a lack of pressure as it does eventually come on and is freezing when it works.
    Not sure if the below code is something to do with this or because of the RNSE Retrofit.
    Any help Greatly appreciated!
    Wednesday,25,July,2012,16:12:06:54899
    VCDS Version: Release 11.11.3 (x64)
    Address 2E: Media Player 3 Labels: 8T0-035-785.clb
    Control Module Part Number: 8P0 035 785 HW: 8P0 035 785
    Component and/or Version: SG ext.Player H08 0100
    Software Coding: 020202
    Work Shop Code: WSC 06314 000 00000
    VCID: F4E2C97557A08E9
    2 Faults Found:
    00447 - Function Limitation due to Over-Voltage
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 6
    Fault Frequency: 1
    Time Indication: 0
    00532 - Supply Voltage B+
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Time Indication: 0
  2. Avatar
    snack-media
    Advertisement
  3. CornRattle
    CornRattle Member
    152
    9
    Those 2 fault codes seem to be alternator/battery related, I'm sure someone will correct me if incorrect.
    00532 - Ross-Tech Wiki
