air bag light
simon.m
hey guys my air bag light has started to come on then go off then come on stays on for up 60secs then off again and so on any idea im
thanks simon
NHN
Site Sponsor
Check connections under the seats.
Icarus83
Mine was the yellow connector under the passenger seat that is the common culprit. Stripped the connector down as it clips apart (with the battery disconnected) cleaned with contact cleaner (or spirit) and re assembled. Then used a code reader to clear the DTC fault code. If you've had success, it won't come back on!
bradh
Active Member
Mine did this scanned it said fault with passenger seat took plugs out sprayed wd40 into both plug ends connected back together no error or light this was mths ago too
Mike.M
loose connections are the main cause but the airbags/ignitors are starting to get on now so some may begin to actually fail the tests the car performs.
