Agu engine
S3Zek
Is the Agu engine internally the same as the bam apart from head and pistons? Any one know what the Agu and bam pistons are good for power wise?
Lewis583
Active Member
Maybe another slight engine tweak...
Have a read of the above. Welly is using an AGU bottom end (Albeit with uprated rods) and a big port head. With the FP Green is puts out 411 BHP/330 LBFT.
Badger 5 Edition...Its all about the flow...
Staff member
Moderator
06A blocks should all be the same (although 210/225 blocks are supposed to have thicker webbing but never looked or checked part numbers)... considering the yanks are getting silly HP figures from Golfs etc that use the 'lesser' block then there isn't an issue as far I can tell...
BAM/AGU pistons are good for 400 odd hp... Welly uses AGU pistons in his and I have Ibiza Cupra pistons in mine which are more or less the same... all good so far...
S3Zek
Cool thanks for that guys I would like to go for around 400-450 ish but I wasn't sure if I would need forge pistons or not, I don't really see myself going any higher than that but is it better to be safe than sorry?
S3Zek
If all gos well I should be picking up a Agu lump to build up at the end of this month, but I didn't know if the standard pistons were up to the job or not.
Welly
335D Driver :-)
It's very much to you mate, standard pistons are exceptionally strong for an OEM item. The are made by Mahle - mine take over 400 bhp currently.
S3Zek
That's quite impressive welly, i suppose it really depends on the condition of the bore and pistons when i get it.
superkarl
MAN OF STEEL
if tuned well and theres no det then surely the pistons will be fine for your power goals.
S3Zek
well hopfuly when ive got it all done it will be making its way up to bill :icon_thumright: its a good treck for me to him but im sure it will all be worth it :cool:
BuuBBa
So did I understood right that AGU engines are with 06A blocks?
Looking for another block which will be stroked to 2.0l, and just want to make sure that wont buy something useless..
Staff member
Moderator
Yes...
