Aftermarket stereo to replace rnse and keep bose
donovan2123
Member
As above can anyone advise what I need to fit a aftermarket double din in place of the rnse? What adaptors etc do I need? Already have factors GPS antenna etc
xkieron99x
you looking for an android unit or a universal head unit, from my knowledge audi a3 specific andorid units are plug in and play.
donovan2123
Member
Kenwood, pioneer etc. To many horror stories and issues I have read about the Chinese no name units.
I want something that will just work with no messing about with firmwares etc
abmat
Well-Known Member
I’ve got a alpine ilx 700. CarPlay unit so I don’t need a gps antenna as I have unlimited data.
You’ll need a Bose harness adapter, facial adapter, probably a antenna booster for the radio and I had to get a cage as the alpine didn’t come with one.
Fitting an aftermarket may induce groundloop, which is quite common with Bose so you’ll have to run a ground from the amp to the headunit.
There are others out there with more bells and whistles but I’m a fan of alpine and liked the look.
How much are you looking to spend?
Get the fascia etc of amazon. Way cheaper than Halfords or anywhere else.
donovan2123
Member
Looking to spend around £400-500 all in. I was looking at the fitting kits, I will also needs GPS fakra to smb adaptor, and double fakra to aerial adaptor.
Is ground loop definitely an issue or is it just an issue with cheaper harnesses?
abmat
Well-Known Member
Can be an issue as a aftermarket can draw more power than std one plus the alternators aren’t filtered hence you can get the annoying whine.
Daveyonthemove
Well-Known Member
I have an Erinis (think thats the correct name) Android unit.
No interference from the alternator, rear speakers work perfectly fine with the Bose system, and no wiring harness' needed. Plug and play.
The GPS on the car won't fit the head unit, but they come with one which works fine mounted under the dash on top of the glove box.
FM radio worked fine, DAB is an option but the aerials that stick on the window's aren't that great.
donovan2123
Member
I have purchased a Kenwood DMX7018DABs and the relevant bits to go with it. Will hopefully have installed over the weekend
ch1z64
C'mon you's bhoy's in Green
Silver Supporter
If you want no problems with your head unit I advise getting someone who does this for a full-time job fitting them
donovan2123
Member
Explain? You had issues? Tbf I am fairly handy so should be okay. Also went for the connects 2 module which is like £60 and means you don't have to mess around with rca cables etc
ch1z64
Silver Supporter
I have never had any problems with my head unit as I like the OEM Rns-e ( does what I need it for ) but over time I have seen so many posts about lads who have fitted Units off all sorts and then they come back asking why this isn't working ie front speakers, crackling noises, problems with Bose etc . That's why I say when it's electrical get the guys that know there way around a cars cause it can work out more costly in the long run .
I do wish you all the best and happy to hear you fit with no problems as it would be horrible to see another post about my head unit not working
donovan2123
Member
Most of which are Chinese branded or they have used the cheap adaptors which are known to cause issue. If it don't work as it should it will be going back and I will be jumping on the branded Chinese rnse lookalike as above.
donovan2123
Member
Fitted today. Install was simple with no complications and no messing about.
Came in around £480 all in, I built the kit myself as the all in one kit didn't have the adaptor I wanted or the FASCIA. I have bose.
DAB antenna is tucked below screen between screen and dash. Bluetooth mic is in the spare hole in light fitting.
All works as it should.
abmat
Well-Known Member
What fascia is that? Is your screen size 7”?
abmat
Well-Known Member
Cheers. As I have cage etc I’ve ordered just the fascia. Cheers for the link I’ve been looking for this one for ages.
Kevinp1992
Hi guys sorry to just jump in on this but I'm looking to put a android one in my car. How easy is it to put one in as i just have the audi concert in at the moment i have the audi a3 8p 2004. Any help and suggestions welcome
donovan2123
Member
Mine was super easy. The hardest part was routing the cables(poking/pushing behind trim with plastic trim tools) which again was easy with glovebox removed.
Do you have bose? Maybe remove your stereo to confirm what connections you have at the back.
If you go for a non cd drive like my Kenwood headunit then they are not as deep so plenty of space behind.
Kevinp1992
Can i buy a kit to remove the cd player? Then i can get it removed will have a better idea what exactly i have. Yes i dont really care about having a non cd unit as I'd rather connect my mobile and radio anyway.
donovan2123
Member
Ye you just need removal keys. Either get them online or go to Halfords and buy. Literally push keys in into each slot then pull stereo out
Daveyonthemove
Well-Known Member
Is the Concert unit a single DIN, or Double DIN?
Kevinp1992
Ok will pick some up tomorrow then cheers. It a single DIN that why i was not too sure about having a screen put in. If it was possible or how difficult it would be.
xkieron99x
you’re going to need to get a double din conversion kit
donovan2123
Member
Okay, I need some advise the kit I got sent was the Connects2 CTSAD006.2 which was a doodle to fit however I am having issues with white noise/static noise, I have turned down the pots on the canbus module but by doing so it turns down the overall volume and just sounds rubbish.
So the question is has anyone else faced this issue? If so, do you try the Connects2 CTSAD002.2 instead?
Eren S3
Pretending to know what I'm doing.
Silver Supporter
I had a Pioneer DA230DAB installed by a company near me who specialise in radio installations and it was a plug and play basically. They wired everything to the Bose system and steering wheels as has been mentioned above. If I remember, I paid around £500 all in to have it supplied and installed.
Is that what that is??! I've noticed I had a whine that seems to match the revs up and down (if that makes sense) and it's only after having a Pioneer DA230DAB installed.
Daveyonthemove
Well-Known Member
Which cable did you use 6.3 or 2.2
Couldn't tell you, I didn't need any thing extra. The loom that was in the car attached to the rear of the stereo and everything was running fine from the start.
People bad mouth the chinese Android Head units, but I can't fault mine. Having ODB Eleven installed also makes it a great scan tool built into the car.
donovan2123
Member
Which unit do you have?
donovan2123
Member
Okay I purchased the connects2 2.2 lead and I now have no white noise or any noises for that matter.
I have bought some ground loop isolators in case I had engine noise but I don't so they will be going back.
