Aftermarket head unit and canbus
christoph
I've just bought a pioneer HU for my a4 b7 2005 and from what I can work out the standard unit uses a low power signal to turn the radio on so doesn't have a proper ignition live, I've tried a wiring harness adaptor but with no ignition live it doesn't work. Do I really need to buy a canbus adaptor as well? I was thinking easiest option is run a ignition live from somewhere else to the wiring harness and that should work fine. Is this the case? I don't want the battery going flat by wiring permanent live and forgetting to turn unit off. And help greatly appreciated.
john777w
You just need to run an ignition feed, you will have a permanent live. Thick black in the fusebox would be my choice, add a inline fuse!
docurley
Moderator
Staff member
Moderator
I tend to find that the adapters for the loom need the main power supply and the ignition live wire swapped round the Audi loom will have a live and a ignition live.
Get your self a simple tester (normally a screwdriver with a wire coming out the top with a bulb built in to the handle) the wire will attach to a earth and you just touch the loom looking for live and ignition live.
