Advise needed on two fault codes please?
dt-tdi
Active Member
In the last couple of days I've had my airbag and a brake warning light come on, don't know if it's just a coincidence or if the two problems are linked?
Scanned the car tonight and it's showing the two following errors, can anyone advise please?
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004426
Shop #: WSC 06325 000 00000
VCID: 2E556239B9BE206E39B-807B
1 Fault Found:
00526 - Brake Light Switch-F
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 35
Time Indication: 0
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x0202
Hex Value: 0x0004
Hex Value: 0xB099
Hex Value: 0x0001
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H12 3730
Revision: 91H12373 Serial number: 0036M0G4MUU4
Coding: 0031612
VCID: 3B735B6D7ACCC5C68E5-806E
Subsystem 1 - Serial number: 6332DRB404360C9EV
Subsystem 2 - Serial number: 6342DRB4042AD42BU
Subsystem 3 - Serial number: 6352ARB401D63E67W
Subsystem 4 - Serial number: 6362ARB401D6387AV
Subsystem 5 - Serial number: 63729RB401D9773CZ
Subsystem 6 - Serial number: 63829RB401D9770AV
1 Fault Found:
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
010 - Open or Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Thanks in advance
Dave
delterflier
I have a similar problem,I've just replaced the sterring rack,front wheel bearings, front brakes and some welding but no have the airbag light on the dashboard.
I had the batterys disconnected the hole time when doing the welding.
I have checked the passager side airbag ie put the key in turn it of start car then do it again but switching it on but no joy.
Would the airbag light on fail a mot?
I'm not trying to hijack just maby between us we could cure both cars :-D
NHN
Site Sponsor
If glovebox has been out make sure the connectors plugged in still & the brake light switch on pedal maybe faulty, check connections.
You need to find out via scan, why your light has illuminated, as there are many airbag system that would light this up & yes mot failure.
dt-tdi
Active Member
I think my airbag light was a blip as Ive cleared the fault codes and it hasn't come back on since(fingers crossed)
The brake pad warning light has come back on so a brake inspection is on the cards for this weekend.
Genuine front pads from Audi are about £90 which I've ordered today to be on the safe side.
delterflier
For me it was because I had the seats out,got the code wiped for 20quid.
I had a warning fir breaks after I put new pads and discs(Delphi) .
Needed tracking done so got it done then funnyly the warning has gone (touch wood)
Hope it helps
John
