Wouldn't touch that either. The front final drive oil change is deemed important and it often gets missed. You really need to go over the service history with a fine toothed comb. If you take out the extended Audi warranty and have a gearbox problem there is a very good chance they will decline to fix it.
If all the 38k servicing has been done that is about £1000 to £1200 saved.
I have just replaced front discs and pads at 30k miles and will be replacing rear discs and pads within the next couple of weeks. The discs are still in wear limit but the pads need changing, so I decided to do both.
With regards to mpg, on my B road work route of about 14 miles I get about 20-21 mpg. That is not driving hard, cars get in the way! I get about 220-240 to a tank.
On a steady (70-80) motorway cruise I will get 300. At 3000 rpm the car is sitting at 88/89 mph it really does cruise effortless.
There are a few cars put there now, don't rush and double check everything. The online history is a good indication, but I would always want to see the invoices to back it up.
Mine has a resonated Miltek that the previous owner fitted so I don't know how the sports exhaust sounded. He changed it after owning the car for less than 6 months. It does sound good
I know Deano had a non res fitted to his when he had it and he thought it was too much after he got over the honeymoon period.
Have you been over to RS246, there is a lot of info there. There is a thread about servicing intervals and what should be done when. Let me know if you can find it, if not I will have a look.
Here it is:
https://r.tapatalk.com/shareLink?ur...share_tid=126617&share_fid=20930&share_type=t
Hopefully it is ok to post this here?
Where abouts are you based you are welcome to have a look at mine.
Sent from my Pixel 2 XL using Tapatalk
