Advanced Engine Treatments
Paul @ Unit 9 Remaps Jun 29, 2015
  1. Paul @ Unit 9 Remaps
    Paul @ Unit 9 Remaps Site Sponsor Site Sponsor
    2,035
    132
    -Sol-X Petrol Treatment has been exclusively formulated for the modern petrol engine, it will:
    Reduce exhaust emissions
    Remove moisture from fuel system & protect against corrosion
    Clean injectors and improve spray patterns
    Free piston rings and sticking valves
    Improve general engine performance
    Dissolve varnish and non volatile residue
    Lubricate upper cylinder area
    Neutralize acids
    -Sol-X Advanced Diesel Fuel Conditioner has been exclusively formulated to:
    Remove moisture from the fuel system
    Lubricate fuel pump and entire fuel system
    Prevent corrosion & bacterial/fungi growth
    Restore all round engine performance
    Suitable for use in common rail diesel engines and for use with ultra low sulphur diesel fuel.
    -Sol-X Advanced Dual Fuel Hyper Clean has been exclusively formulated as an advanced, easy to use fuel line cleaner. It will:
    Improve performance, fuel economy and cold starting
    Prevent corrosion and control fuel oxidation
    Reduce black smoke from diesels
    Remove water from fuel tank and lines
    Clean spark plugs and lambda sensors
    Lubricate and clean the entire fuel system
    Suitable for petrol and diesel engines.
    Safe for use with common rail diesel engines.
    -Sol-X Induction System Cleaner has been exclusively formulated to:
    Clean and lubricate throttle body, idle air intake, air intake butterfly
    Clean carburettors
    Dissolve gum oil, varnish, and other impurities
    Help prevent surging, stalling and hesitation
    Reduce emissions
    Clean P.C.V valves
    Oxygen sensor safe
    Safe on coated throttle bodies
    360˚ Valve for ease of use
