  2. Dismiss Notice
Added too much oik
Richsmif Jun 14, 2019
  1. Richsmif
    Richsmif Registered User
    My oil level was about 50 percent on the mmi screen. I added some slick 50 Synthetic which is 750ml.
    Oil level now shows max and says please reduce oil level.
    Been driving super smooth no issues with 38k on the clock
    Should i drain a tad out or just leave it to burn down naturally. Cant be more than 100 or 200ml over.
    Would that cause a problem in time?
    2016 a5 black edition
    Sent from my SM-G930F using Tapatalk
  2. Avatar
    snack-media
    Advertisement
  3. MuPPeT_ON_TouR
    MuPPeT_ON_TouR Well-Known Member Silver Supporter
    490
    301
    A very quick google search on the topic says your engine will self destruct (I'm paraphrasing of course)
    I would remove the excess ASAP.
    Meemo and JG51 AUD like this.
  4. CHEZ
    CHEZ moderately amusing Supporter
    7,382
    1,672
    Definitely remove some oil.
    Also would not mess about with oil additives either.
    Long term gum build up is inevitable no matter what Halfords etc have told you otherwise.
    Drop the lot, fill with lovely fully synthetic decent oil.
    Sorted
    Oh, and buy a dipstick
    JG51 AUD likes this.
  5. Ryan Evans83
    Ryan Evans83 Registered User
    21
    Sounds stupid, but to be sure, will the MMI oil status still work if you fit a dipstick? I know the “tube” is there for the dipstick but it’s blanked off, wasn’t sure if the sensor was in the tube as a result.
  6. CHEZ
    7,382
    1,672
    The dipstick people buy are just used to check.
    It does not live in the tube permanently.
    Once you're done checking the oil, remove the dip stick and replace the rubber bung.
    I believe the sound proof material hits the top of the dip stick when you close the bonnet, or something similar, but it's not advised to run the car with the dipstick in the tube.
    I don't anyway.
    The mmi resets itself once you open the bonnet, so have to wait 50 miles before you get a reading.
    That's one of the reasons I bought a dipstick, you get an accurate reading immediately, not running the risk of over filling.
    Ryan Evans83 likes this.
  7. Ryan Evans83
    21
    Thanks that makes perfect sense. Is there a recommended dipstick to go for?
  8. CHEZ
    7,382
    1,672
    I just went to TPS and gave them my car details.
    Iirc was about £20 I think, I may be wrong because was a long time ago.
    Oddly, the Audi dealer would not sell me one.
    They said it was not required or listed.
  9. Meemo
    Meemo Registered User
    1,257
    843
    I got mine for £12 direct from Audi, was cheaper than the aftermarket places and ebay. Just have to find your part number first, I would pass mine but I got one for an S5 so likely not going to work with yours.
    Equally I have left the dipstick in permanently, but it is lower than the engine cover so no rubbing issues.
