  2. Dismiss Notice
  1. Phil73
    Phil73 Registered User
    66
    54
    Just thought I would share my experience of topping up for the first time. Having done 6000 miles now, about to go abroad next month and no way of knowing if it was delivered with a full tank, best thought would play it safe.
    I have the 24 litre tank and having checked I could top it up at a nearby service station on the M5, Frankly north, did so on a way to a meeting last week.
    The cashier (Welsh Mark) was great, showed me a few options, 2 litre bottle ( can't remember the price), 10 litre bottle with filling attachment for £16.99 or the pump on the HGV island if the nozzle fitted at 89p a litre.
    Bit of a no brained to try the HGV pump first, the nozzle (bp) fits in and having had to go back to the shop to swipe the card for the pump first, topped up with 11 and a bit litres in no time.
    So based on that you use 1 litre about 550 miles. So should be ok now for another 12000 miles! Dead easy and mucho cheaper than the containers.
    Phil
    190 tdi sline avant auto, moonlight blue, adaptive sports suspension, tech pack, 18" wheels, and a few other toys..
  2. Avatar
    snack-media
    Advertisement
  3. ScottishA4B9
    ScottishA4B9 Registered User
    3,412
    1,017
    Thanks for sharing that! It's the first review I've read of real world Ad Blue use.
  4. cjp2k
    cjp2k Registered User
    355
    58
    Thats interesting about the hgv pump. My mother in law has a b8 tdi ultra with ad blue. Took it to the nearest she'll with adblue. Pump fit but it kept cutting out. Ended up buying a big container of the stuff and putting it in by hand...
  5. Phil73
    66
    54
    The pump did cut out once or twice, think it was because squeezing nozzle handle all the way ie not throttling it. It cut out finally when full and would not allow anymore in much the same way when filling with fuel.
  6. B5NUT
    B5NUT Well-Known Member VCDS Map User
    5,108
    1,248
    I've only done 1650 miles on my 16 plate A6 C7 and decided to top up the tank, manged to get over 7 liters in there before it was full, so I don't believe they fill the tank from factory.
  7. Dan241085
    Dan241085 Registered User
    62
    31
    I've just had a 2000 mile warning for adblue come up on my B9 A4 after 8500 miles.
  8. Krusovice
    Krusovice Registered User
    111
    53
    Is that with the standard 12l tank and 3.0?
  9. Dan241085
    62
    31
    I went for the larger 24ltr tank and yeah it's the 3.0 (218). I have read previously you should get around 10k miles until top up, so seems about right
  10. Krusovice
    111
    53
    Is that assuming it was full to start with? Seems like they generally aren't.....
  11. Dan241085
    62
    31
    Just read on another forum, they topped a 24ltr up to full and it came back with 10500 mile range. Seems I got lucky and the dealership filled it to the top (unlike the oil which I have had to top up recently)
  12. Avatar
    snack-media
    Advertisement
  13. Krusovice
    111
    53
    Oh, okay.
    Slightly off-topic, what engine oil did you use to top-up as I am about to set off on a multi-thousand mile continental trip and mine is showing just over half full at 3k miles?
    BTW I have 3.0 (218) also...
  14. Dan241085
    62
    31
    I just used the oil which was supplied with the car, found it in one of the compartments in the boot
  15. Bungle17
    Bungle17 Registered User
    58
    15
    For anyone interested, I've recently had the 2k warning for AdBlue, after 3,500miles in a 190tdi with the normal size tank. Seems slightly higher consumption than some others in this thread but presumably the dealer didn't quite fill mine at new.
  16. h1r4
    h1r4 Registered User
    304
    178
    43
    Dealer will fill less than half full
  17. Inverted
    Inverted Registered User
    71
    42
    Picked up my Avant yesterday.
    It has the larger SCR tank. I nipped into our local hardware store and they had Greenox Adblue 5L for £6. So just over £1 per litre. The car only needed 3L to fill, so the dealership put plenty in. I'm guessing a standard of 20L on top of the minimum from the factory.
    The dealer said they have to put in Adblue supplied by Audi as part of the PDI, which works out at £1.20 per l.
    Good ol Pig wee & Water!
    mjcourtney likes this.
  18. Colh
    Colh Registered User
    131
    I'm at 3600 miles in my 190, and so far so good. My dealer (Coventry) said on pickup that they had checked and topped up oil and adblue. I've also got the bigger tank. Depends on your dealer I suppose.
    Is there an adblue gauge anywhere?
  19. A4B9
    525
    271
    I'm nearly up to 7000 miles and it's still going strong. Like @Colh i picked mine up from Coventry so they must have topped mine up as well
  20. A4B9
    525
    271
    Adblue warning has come up at just over 7500 miles. I wish petrol stations would start adding pumps for it on their forecourts
  21. holly35
    holly35 Registered User
    428
    154
    43
    Ad blue along with heavier tyre wear , additional oil consumption and less refinement was why i chose the tfsi.
    I feel the whole adblue issue is a backward step and more hassle for owners only to provide manufacturers with achieving set figures.
    Really if manufacturers struggle to reach these values why on earth are these unachievable figures set in the first place?
    In 2016 there must be a better way than standing pouring pig pee into your new high tech luxury car.
  22. cuke2u
    cuke2u Well-Known Member
    12,914
    5,244
    But the manufacturers don't set the unachievable figures in the first place do they, it's just the manufacturers being forced to comply. Next from the legislator's it will be, and I know this to be true, dpf's for all our petrol engines in a few years time to meet the targets. VAG already have some in the pipeline for next year..
  23. holly35
    428
    154
    43
    Yes perhaps my wording is misleading , i do understand its not the manufacturers fault .But the relevent goverment departments and assosiated bodies.
    Still it was enough to personally put me off diesel power......
  24. holly35
    428
    154
    43
    ..dp filters , another giant pain in the *** , just great for all those short trips..bound to clog up leading to a trip to your dealer requiring ££££££££.
    What i find laughable with these "goals" is unfortunatley the benifits are completely undone every time someone passes you in a smoke screening old banger leaving a vapour trail 3/4 mile behind it and choking your lungs as it passes......
  25. cuke2u
    12,914
    5,244
    Fortunately particulate filters on a petrol engine don't quite have the same issues as one on a diesel, as the exhausts run hotter, thus any regens will not require forcing. However it is an extra cost on the purchase and maintenance on a owner and there might be a hit on performance as well...
  26. A4B9
    525
    271
    Don't tsfi engines drink oil like there's no tomorrow?
    AdBlue is such a minor inconvenience that it's laughable you use it as a negative against the diesel variants. Oh no, I have to refill it once, maybe twice a year at a tiny cost - what hardship...
    Better fuel efficiency trumps everything else when I'm covering hundreds of miles a week. To get 3 weeks worth of driving for every tank is good going for a quattro, doubt I'd be getting that with a petrol
    Mike north east likes this.
  27. cuke2u
    12,914
    5,244
    Nope, mine hasn't used a drop neither has any of my petrol engined cars. Personally I have no comment to make about ad blu but there is the fact that diesel engine manufacturers are struggling to stay within the current emmission limits and they seem to have run out of ideas. The use of this engine in passenger cars is definately on the way out and some manufacturers are going to drop oil burners from their range very soon. Yet the petrol engine is still coming out with different technology...
  28. maui
    maui Registered User
    499
    206
    43
    I genuinely wish that my next car in 2-3 years will be hydrogen powered - eradicating the need for adblue and whatever else - it remains to be seen how likely that will be. Until then I'm optimistic about going from Diesel to petrol.
  29. cuke2u
    12,914
    5,244
    Me too, however for some reason I'm not seeing much development in the area of hydrogen powered engines. The emphasis seems to be electric with the batteries being so environmentally devastating...
  30. holly35
    428
    154
    43
    My comments on adblue are purely personal and i found it an extra additional issue i could do without.Every one picks and chooses what suits them.With regards to oil consumption and tyre wear i was going by past experience with my A4 tdi which could only muster around 12 k from a set of front tyres ,where my petrol A3 is currently on 22k and still not down to its markers.It also liked a sip of oil now and again.......My petrol A3 did use some oil on running in but not after that.Factor in the smooth quiet power from the petrol and that was enough for me,,,,,,,,,
  31. alFR
    alFR Registered User
    230
    77
    See here. ;)
    A4B9 likes this.
  32. DrEskimo
    DrEskimo Registered User
    2,487
    2,381
    How so? Devastating seems slightly over zealous, and something I would reserve for fossil fuels!
    You have the issue of precious metals needed, but hydrogen has the same issue. Recycling of batteries can certainly circumvent this.
    I thought hydrogen was lagging because it primarily uses methane as its source of hydrogen, with high energy needed to separate it.
    The advantage of EV is that it's entire production has the potential to have zero reliance on fossil fuels.
    If there were alternative sources for hydrogen, then fuel cell technology could surpass EV, but then you still have the issue of building the immense infrastructure to replace what's already there for standard fuels. This is the same issue with EV, but they have already started making huge headway, thanks largely to Tesla.
    To me the advantages of hydrogen is that you can 'recharge' the car in minutes, much like a standard car. But EV is already making massive headway with super fast charging. The disadvantage is that currently hydrogen is mostly extracted from methane gas (think fracking and the likes) and the high energy needed to separate the hydrogen, something that EV doesn't have to consider. For me that makes EV a much better alternative.
    Perhaps hydrogen needs a rather rich bloke to kick start it...?
  33. Avatar
    snack-media
    Advertisement
  34. DrEskimo
    2,487
    2,381
    Back slightly on topic...
    The ever increasing regulations on emissions (and rightly so...) means that diesels won't be viable much longer, and it won't be long till petrol reaches the same point. We've seen the lengths VAG have gone to to try and produce diesels that don't require adblue to meet EU5 regulations, and the fact they resorted to such a risky and damaging tactic of cheating, suggests to me that they are reaching the limits of what is capable from Diesel engines, in terms of engine technology and exhaust management hardware to reduce harmful emissions.
    cuke2u likes this.
