Activate parking display on MMI
Jenks88
Morning guys,
After a quick Google search a stumbled across this forum and have found it to be a plethora of knowledge!
I was just wondering if someone could code my parking sensors (rear only) to display on the MMI. I am located in South Yorkshire, but work in Nottingham so happy to commute to any of the surrounding areas.
alpesh26
Welcome mate!
I don't believe it is possible to activate the MMI display with VCDS if you have rear sensors only on a facelift car . I'm sure someone will confirm but I think it was only possible on the pre-facelift
Ice Kay
Active Member
Welcome mate!
it can be done PFL, i did my brother car and he only has rear sensors.
Ice Kay
Active Member
Morning guys,
i live in leicester if you can make it to me
alpesh26
I think the OP has a facelift car looking at their profile pic
Ice Kay
Active Member
Cheers for the replies, yea its a FL. Is it still possible?
As yours is a FL and you don’t have front sensors, I’m afraid I don’t think it’s possible.
I can still give it a go if you want, if it don’t work then no charge
Jenks88
Ah thats a little annoying. Do you guys know anyone who can retrofit a oem reversing camera in that case?
JohnM100
Gold Supporter
On facelift, you’d need to upgrade to parking system plus ie front sensors before you can get the reversing camera. If anyone can, it’s @DJAlix.
Jenks88
Yea I'm beginning to learn that! I thought it might just a been a case of having a camera retrofitted and coded. Didn't have a clue it would need front sensors too!
AlS3BE
Camera won’t give you those parking lines just the video feed. Still need front sensors or a modded parking module.
Gemrom
Hi there. I coded my rear sensors to display on MMI using Carista.
I got a free 7 day trial but was so pleased that it worked that I paid for a years subscription.
Enabled a few others things with it too, such as chirp, needle sweep, open and close sunroof with long key press etc.
Bargain
DJAlix
VAG Car Coding™ Limited
Site Sponsor
Gold Supporter
VAG Can Professional
ODIS (Offboard Diagnostic System)
Bargain
You have a pre-facelift vehicle then.
Neil C
Couldn't do chirp on my 2014 S-Line Sportback. Apparently I don't have the right module to allow it.
Gemrom
Hi guys. I’ve got a 2014 1.8 Quattro, 3dr in black with factory fitted black pack. It’s got a great spec and I absolutely luv it. Carista a bargain for enabling rear sensor MMI display and minor mods.
