accelerator problems
ben parris Mar 7, 2018
  1. ben parris
    ben parris New Member
    29
    HI all,
    I'm having some issues with my accelerator, car is audi allroad 2.5 tdi v6 2004. Lots of mods and mapped.
    When I steadily rev up from idle, as I hit 2200 revs the revs drop down 400 rpms, but my foot has remained in the same position.
    I have looked at data measurement blocks, channel 01
    IQ fluctuates between 1.88-2.60
    RPM at idle is 745-765
    Idle Stabilization at idle fluctuates between 25.00 -26.85 deg kw
    when I rev as above and the stabilization reaches 50 deg kw it drops back to 30.
    I don't know if this is normal
    ben
  2. Avatar
    Google AdSense Advertisement
  3. ben parris
    29
    Forgot to say this is whilst stationary.
  4. Samuel c5 Q
    Samuel c5 Q Active Member Silver Supporter VCDS Map User
    581
    111
    43
    Throttle position sender? Disconnect and check for resistance as it's moved from one position to another.
  5. ben parris
    29
    Tried a new pedal, just the same...
  6. Samuel c5 Q
    581
    111
    43
    I don't know about the idle stabilisation bit sorry. What about boost control? Would that be about the full boost point for those cars, 2200 rpm? Is the boost dropping off for some reason and the fuelling is dropping to match and then the revs are dropping.
  7. thawatchai2510
    thawatchai2510 Member
    92
    VCDS dianostic.
