ABS/ESP lights but no error codes?
norris_309
MOT approaching fast & i've had the ABS & ESP lights coming on intermittently for a while now.
Originally my amazon special code reader did pick up a code relating to the rear right wheel speed sensor (think it was code 287), however this past week the lights have been on constantly, I put the code reader on to confirm it is the same code & now it's reporting no codes present?
I also tried a bluetooth code reader that has worked in the past, again no error codes?
I have just now pulled the battery -ve off & then tried again, in the hope it's reset itself, but still then same?
Any ideas on what i can try? (short of taking it somewhere for vcds)
NHN
Site Sponsor
Probably the sensor or bearing at fault if its the same abs design, I'd strip & have a look at both, given age of car, bearing probably has deterioration on the abs ring causing intermittent sensor faults.
norris_309
Yeah i think i'll have a look at the state of the sensor over the weekend. Just odd how it's keeping the lights on but now showing no error codes?
when looking at them ages ago, the abs rings look like they were found at the bottom of the sea! but at that point they were working (it was the steering angle sensor playing up!)
norris_309
Seems i have the error back now and also it's decided to pop up the 1826 error code as well, that refers to the steering angle sensor... again!
I'm hoping the 1826 code is something to do with disconnecting the battery & it having to calibrate (clutching at straws???) as i don't fancy messing with that again.
Had major issues with weird eps/abs/braking effects last year. swapped the steering angle sensor which cleared the faults & the braking issue?... that seemed to resolve itself when i added a teaspoon of brake fluid & pressed the fluid level switch in the reservoir?
Anyway,
MOT in 3 weeks.... eeeek might get the rear right wheel off & see if I can see anything up with the sensor as that's what the error indicates is up. Then maybe chuck it on for mot anyway & see if anything else gets picked up before forking out on having the sensor replaced.
Cars now on 181k miles but the car itself is in pretty nice condition.
