I am looking for some assistance with a replacement ABS pump & brake controller that I installed in my 2007 AUDI A3.
No one on the Ross-Tech website has been able to provide any information during the past 3+ weeks that can explain why a brand new replacement ABS pump and controller is not recognized as a functioning controller in my car.
Background Info:
My original ABS Controller (1K0 907 379AC ) registered a fault ( 01435 ) for failure of Brake Pressure Sensor 1 ( G201 ). A scan of the ABS controller prior to the replacement is shown below:
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Control Module Part Number: 1K0 907 379 AC HW: 1K0 907 379 AC
Component and/or Version: ESP FRONT MK60 0101
Software Coding: 0021122
Work Shop Code: WSC 06314 000 00000
VCID: 73EE5E151222D6DC15-8026
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
012 - Electrical Fault in Circuit
I replaced the complete ABS unit ( full AUDI part number: 1K0 614 517 H BEF ) which included a new ABS pump and new controller ( 1K0 907 379 K ). I coded the new unit with the appropriate coding value ( 0021122 ) for my specific car, which was the same coding as my original ABS controller. I do not have any error codes, but I show three (3) error lights on the dashboard: ESP light, ABS light and blinking BRAKE light which are associated with a brake system failure. A scan of the new ABS controller is shown below:
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021122
Shop #: WSC 00000 444 00000
VCID: 3A70B33175C867942A-806E
No fault code found.
I performed all the basic setting that apply to my specific vehicle, including Steering Angle (G85), Lateral Acceleration Sensor (G200) and Brake Pressure Sensor 1 (G201). I also had to perform the ESP System Functional test to clear code 01486, which successfully cleared this code. ( I noticed that during performance of this System Functional test when brake pedal was pressed to initiate the test, the indicator lights on the dash did not change status ).
Some basis setting don't apply to my specific vehicle, including Longitudinal Acceleration Sensor (G251) and Tire Pressure (TPMS).
- What additional programming is required to have the new ABS pump and controller recognized as a properly functioning unit ?
- Is there a requirement to update the Label file for this new controller ?
- Is additional adaptation or a firmware update required ?
Background Info:
1 Fault Found:
Coding: 0021122
