hello guys, i bought this car a while ago and got the engine replaced cause of camshaft wear(as usual). replacement engine has no problems,but haven't managed to sort out the abs no matter what.got a vcds and a full scan but can't find the cause of the abs problem. temporarily replaced the abs unit with the module with exact same number as mine to check if it will fix the problem but vcds could not communicate at all. so we swapped the abs unit again.i also have an aftermarket radio. any help is greatly appreciated here is the log of the vcds.
