ABS and ESP light has come on, brake lights not working?
jimbob79
Hi there,
i have a 53 plate B6 1.8t, which I've owned for a couple weeks now.. The ABS and ESP light came on earlier, I read on another thread that the first thing to check should be brake lights which I thought odd, however to my surprise all 3 brake lights appear to not be working.. Have checked all the fuses which are all ok.
My question is do I need to replace the brake switch on top of the brake pedal? If so, is it an easy enough job and how much are they?
Any help would be appreciated..
cheers
Jim
jimbob79
Hi Quattrojames,
Think you've sent the wrong link. The link you have sent takes me to my post. :)
Jim
quattrojames
Moderator
Staff member
Moderator
I haven't sent you a link yet!
I think thats a system generated email because you've subscribed to your post!!
Will email you now.
jimbob79
Just received, I'll pick the part up tomorrow and give it a bash. Is it worth getting from the main dealer or someone like eurocarparts? Thanks again for quick response..
Jim
jase0851
Last time I replaced one it took 5 minutes and the switch was 14 quid from vagparts
pauldazzle
N.B. The new VAG switches don't require the pedal to be depressed, just insert & turn the whole switch clockwise till it clicks. The click is the lock disengaging, if it doesn't click it won't work.
