hello i have an audi a8l 2004 4l tdi and i have issues with my fuel system fuel pump pumping fuel in to fuel filter but i dont seeing fuel in those fuel rails is there is any whay to blead/prime that ?
Please tell me you haven't broken into the fuel rail or cracked off any injectors? It's high pressure common rail and requires specialist equipment to discharge safely and re-pressurise afterwards.
Which nut did you loosen? Were you told to by a qualified mechanic?
You should NEVER loosen anything on a high pressure fuel system. You bleed the system by operating the starter for 10-15 seconds several times until the engine fires. Chances are you've now lost all pressure in the common rail.
