A7 Front Camera Fault
RaymyM
So my front camera has stopped working on my 2015 A7 facelift, see photo. I've also got this error when I ran VCDS:
2 Faults Found:
9616921 - Supply Voltage for Front Surroundings Camera
B1284 12 [009] - Short to Plus
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 58
Mileage: 113557 km
Date: 2022.04.02
Time: 15:43:09
Voltage terminal 30: 14.2 V
Terminal 15 status: Terminal 15 on
9616922 - Supply Voltage for Front Surroundings Camera
B1284 14 [008] - Open or Short to Ground
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 99
Mileage: 113602 km
Date: 2022.04.03
Time: 10:27:04
Voltage terminal 30: 10.7 V
I'm guessing I need a new camera which are extortionate to see the least. In or around £300. Part number: 7P6 980 551 C.
Anyone know if the same part is available under a different guise in the rest of the VAG group for less?
A7 Front Cam Error
NHN
Site Sponsor
Check power feed to the camera 1st.
RaymyM
Will do. Just checked fuses so far but I suspect that's a bumper off job to get at it?
RaymyM
Anyone know where the control module for the camera is located? I suspect it may be at fault but the camera doesn't seem to be getting power. Or is there a way to test it with VCDS?
