A6 Le Mans wanting to fit 20" A5 alloys
Ali2.0tfsi
Hi guys I'm looking to fit some 20" A5 rs4 style alloys genuine
They are 9x20 ET 29 with 265/30/20 tyres.
Will these wheels and tyres fit straight on my 2009 model A6 or will I have issue with rubbing etc etc advice please thanks.
NotNormal
Active Member
I am running 255/35/19 Audi A5 9j 19's with et33
The only thing I needed to adjust was the rear inner arch liner.
The wheels don't catch or scrape at all and my cars on eibach pro springs
The 265 cross section tyres is a no no
You might get them to fit and work with a narrower tyres but personally I wouldn't want to run skinnier tyres than standard as grip you should have.
GDS968
A6's can run 225 width tyres from the factory so width should not be a problem if going narrow!! 265 is too wide for sure.
lmarius
255/30-20 8,5J ET 33 on a quattro with adaptive air suspension is a go go without adjustments on inner arch. And that's about the biggest on a C6 / 4f you'll get without adjustments.
gavin_tully
Can I ask what bulb you are using for the DRL in the picture. They look great.
DasAutos
I have 19x9 RS6 ET33.
I would say that it is maximum you want go, even with this setup its not 100% without any rubs.
I noticed this summer with fully loaded car driving through Germany, it rubs somewhat with 255/35/19 tires, but its only against the felt, not against the sidepanel.
My car is lowered with HR 40mm
Ali2.0tfsi
Hi guys what about 20x9j ET46 with 265/30/20 tyres would they fit a C6 without any issue or are they a no go?
