  2. Dismiss Notice
A6 C6 tailgate drain
KrisKrk Jan 12, 2020
  1. KrisKrk
    KrisKrk A6 C6 4F 2010 LeMans Avant
    2,797
    2,524
    Goys/Gals,
    Is there a drain hole in the tailgate itself?
    Noticed tailgate halves of tail lights misting up from inside and decided to investigate.
    Foam seal was moist and water was slooshing inside the tailgate, as I was closing it.
    For a quick fix, decided to add rubber seal I've used on tailgate seal itself.
    As the seal was B profile, it was too thick and caused the lamp not to sit flush with tailgate surface.
    Sliced it off to leave me.with thin I profile and it did helped but lamp still is not flush.
    Still got the water in the tailgate so will need to strip it down to investigate further but suspect also faulty seal around the rear wiper motor[​IMG]
    Sent from H P20 PRO
  2. Avatar
    snack-media
    Advertisement
  3. Novica
    Novica Registered User
    35
    24
    The early models had problem with washing jet pipe entering the tailgate. Check that pipe if cracked.
    Sent from my Redmi Note 7 using Tapatalk
    KrisKrk likes this.
  4. NHN
    32,321
    2,512
    Hosepipe & a friend to find the fault.
    SpecialWarr likes this.
  5. KrisKrk
    2,797
    2,524
    Thank you guys for kind tips.
    Will check the washer hose but for now, I have stripped the tailgate of trims so I can get that water out.
    I have inserted cloths in each corner and closed & open the tailgate several times.
    Cloths were soaking wet.
    Managed to get it all out so no more slooshing.
    Now is to wait for the lamps to dry out and evaporate any internal moisture.
    Could take them home to dry out overnigjt in room temperature or in storage with boiler in but have no other car or replacement lamps. Defo will not get up earlier to fit these back in and don't want DIS errors either, if driven without them or rain in.
    Will drive around with heating max on and see what happen.
    Will monitor eventual further water ingress.
    Sent from H P20 PRO
  6. abmat
    abmat Active Member VCDS Map User
    991
    221
    43
    Open the tail gate. On the lower edge you will see two black grommets at each corner. Remove these and any excess water should drip out.
    just be careful as they are fragile.
    KrisKrk likes this.
  7. KrisKrk
    2,797
    2,524
    Thank you for that.
    Think I've seen them there and wondered if they are covering holes through to the inside if the tailgate.
    Have the tailgate trim off atm and looking at any eventual water ingress from elsewhere. Took both of the tailgate pistons off to make sure, boot is closing properly. Time will tell
    Sent from H P20 PRO
  8. KrisKrk
    2,797
    2,524
    That was spot in tip, mate. Thank you.
    Both points
    1. water just drained out through them holes
    2. These plugs are fragile. One completely broken, second one, just partly
    Weather doesn't help to set it out so will have to wait bit longer
    Sent from H P20 PRO
    abmat likes this.
  9. abmat
    991
    221
    43
    No probs. Glad I could help.
    with mine you could hear the water sloshing in the tailgate when you opened it. Did this and it hasn’t returned since (2+ years)
    KrisKrk likes this.
  10. KrisKrk
    2,797
    2,524
    I'm hoping to investigate possible ingress.
    Think it is via poor seal on the lamps I got from another user, as second hand. Lamps are fine but the seal wasn't looking too good on them.
    I did add another layer of rubber window seal but it got lamps sticking out of the tailgate surface much. Maybe because the rubber wasn't bending on lamp corners properly or got slipped somewhere.
    Will remove lamps to take that extra seal off and dry it all off. Put new seal, reinstall again with those plugs blocked and observe.
    If that doesn't help, silicone will be my last option. Clear one on the lamp and tailgate connection and in the gaps.
    They don't need to be removed, right?
    Don't want to leave these drain plugs open without solving the problem
    Sent from H P20 PRO
    daytonamart likes this.
  11. KrisKrk
    2,797
    2,524
    Right,
    Stripped out the tailgate lamps again last night.
    Removed slightly worn out gaskets and used B profile rubber gaskets but stick them in the lamp cavity.
    Than, used E profile rubber gasket on the holding brackets and tailgate internal part of the lamp cavity, where brackets mount and hold on. This provided with more fixing force and allowed lamps to sit flush on the tailgate.
    Lamps are sitting better now and should not allow any water ingress.
    NS lamp had a bit wet old gasket around the top part so suspecting that was the problem.
    It rains today so good opportunity to check it.
    I have plugged the tailgate drain holes to allow any water show in the tailgate, if any will still come in.
    Time will tell but got the gut feeling I will soon resolve the issue[​IMG][​IMG]
    Sent from H P20 PRO
  12. Avatar
    snack-media
    Advertisement
  13. KrisKrk
    2,797
    2,524
    Didn't worked anything and water still get in.
    Think have to spend some time locked in the boot, when it rains outside and observe for obvious leak.
    Wonder what would Police said, if passed by?
    Sorry officer, trying to see the leak source?
    Hahaha
    Sent from H P20 PRO
  14. KrisKrk
    2,797
    2,524
    Got the oem gaskets from West London stealership 4F9-945-192 & 4F9-945-191 for tailgate lamps as a last hope.
    Just applied them in without tapping in to place to allow adhesion in correct places of pressure.
    Took the back windscreen surround trim and inspected further for any leakage signs but nothing.
    That makes me believe that, these lamps were the whole culprit.
    Awaiting rain to confirm
    While I was inspecting the tailgate, noticed one corner of the Sline package tailgate spoiler slightly lifted off.
    Now, SE models don't have these spoilers so there should be no holes that spoiler is attached through, right?
    From google search, these are just stuck on.
    Sent from H P20 PRO
