Here's the log. (battery fine, replaced about a year ago). The car has occasionally gone to Limp Home mode for no logged reason and always re-set and run fine on re-starting. It's done this for a couple of years, maybe once every couple of months, nobody has ever found a fault. It has recently done it several times in the last couple of months. The heater controller is a perpetual misery, but I just live with that.
Richard
Saturday,02,October,2021,14:37:56:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ4F16N102173 License Plate:
Mileage: 226950km-141020mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61 62 72
VIN: WAUZZZ4F16N102173 Mileage: 226950km/141020miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BLB.clb
Part No SW: 03G 906 016 HS HW: 028 101 255 7
Component: R4 2,0L EDC G000SG 9673
Revision: --H01--- Serial number:
Coding: 0000072
Shop #: WSC 00164 210 89795
VCID: 7BFFEFAC3A1BA1C6C11-802E
6 Faults Found:
005697 - Please check DTC Memory of A/C Controller
P1641 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 220027 km
Time Indication: 0
Date: 2021.02.06
Time: 12:05:36
Freeze Frame:
RPM: 945 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.91 V
Bin. Bits: 00101000
Temperature: 49.5°C
(no units): 0.0
005510 - Engine Mount Solenoid Valves (N144/N145)
P1586 - 000 - Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.69 V
Bin. Bits: 00101000
Torque: 0.0 Nm
Torque: 351.4 Nm
012547 - Motor for Intake Manifold Flap (V157)
P3103 - 000 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 44
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 11001100
Torque: 0.0 Nm
Torque: 351.4 Nm
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 13
Reset counter: 255
Mileage: 225817 km
Time Indication: 0
Date: 2021.08.16
Time: 10:34:23
Freeze Frame:
RPM: 2394 /min
Speed: 73.0 km/h
Load: 100.0 %
Voltage: 13.91 V
Bin. Bits: 00101000
Absolute Pres.: 2325.6 mbar
Absolute Pres.: 1805.4 mbar
005686 - Powertrain Data Bus
P1636 - 000 - Missing Message from Airbag Controller
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 255
Mileage: 226958 km
Time Indication: 0
Date: 2021.10.02
Time: 14:25:41
Freeze Frame:
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.83 V
Bin. Bits: 00101011
Torque: 163.5 Nm
Torque: 0.0 Nm
006215 - Please check DTC Memory of ABS Controller
P1847 - 000 -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 255
Mileage: 226958 km
Time Indication: 0
Date: 2021.10.02
Time: 14:27:39
Freeze Frame:
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00101100
Torque: 158.6 Nm
Bin. Bits: 00000100
Readiness: 1 2 0 0 0
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
Component: ESP 8.0 front H04 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020855
Shop #: WSC 02325 785 00200
VCID: 2C5D1CF08FF5F67E18B-8079
1 Fault Found:
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 153
Mileage: 226958 km
Time Indication: 0
Date: 2021.10.02
Time: 14:33:27
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0080
Hex Value: 0x0013
Hex Value: 0x1694
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10600700286747
Coding: 0000145
Shop #: WSC 00164 210 87180
VCID: E3CF37CC22ABF906691-80B6
Subsystem 1 - Part No: 4F0 910 131 D
Component: FBSAUDIC6 EZS H45 0070
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H39 0040
No fault code found.
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 730 F HW: 4E0 035 729
Component: Interfacebox H43 2120
Revision: 00000000 Serial number: 350JQ057612933
Coding: 0001002
Shop #: WSC 02323 785 00200
VCID: 244DF4D0E7253E3ED0B-8071
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H03 0050
Subsystem 2 - Serial number: 00000000262584
Subsystem 3 - Serial number: 0125.10.050000000100010364ÿ
Subsystem 4 - Serial number: 010364ÿ
1 Fault Found:
01320 - Control Module for Climatronic (J255)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 187
Mileage: 225349 km
Time Indication: 0
Date: 2021.08.06
Time: 13:34:38
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F2 820 043 H
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000000190981
Coding: 0001300
VCID: DBBF0F2C1ADBC1C6211-808E
1 Fault Found:
00256 - A/C Pressure/Temperature Sensor (G395)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 235
Mileage: 220027 km
Time Indication: 0
Date: 2021.02.06
Time: 11:29:11
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 D HW: 4F0 907 279
Component: ILM Fahrer H15 0190
Revision: 00000000 Serial number: 4F0907279
Coding: 0000101
Shop #: WSC 02335 785 00200
VCID: 2A511AE88501E84EEA7-807F
Subsystem 1 - Part No: 4F2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE8001487
Shop #: WSC 00000 000 00000
VCID: 1C3DCC30DF5506FE68B-8049
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026052880068
Coding: 0102042
VCID: E6C92ED8D1998C2E8EF-80B3
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0080
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 235
Mileage: 220027 km
Time Indication: 0
Date: 2021.02.06
Time: 11:29:06
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 L
Component: KOMBIINSTR. M73 H11 0660
Revision: 00100000 Serial number: 4RA14TLA5
Coding: 2308443
Shop #: WSC 00164 067 57207
VCID: 1E39C638C94914EE86F-804B
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 153
Mileage: 226958 km
Time Indication: 0
Date: 2021.10.02
Time: 14:25:43
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300805A2681AA
Coding: 6CEE53C41B0104
Shop #: WSC 02334 785 00200
VCID: 2757E3DC9613D526F59-8072
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 226958 km
Time Indication: 0
Date: 2021.10.02
Time: 14:25:42
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0080
Revision: 00-00000
Coding: 0003610
Shop #: WSC 02327 785 00200
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 187
Mileage: 225349 km
Time Indication: 0
Date: 2021.08.06
Time: 13:33:48
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01008252020000
Coding: 0000763
VCID: 2E5916F8B9E9846E36F-807B
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 187
Mileage: 225349 km
Time Indication: 0
Date: 2021.08.06
Time: 13:33:52
01366 - Opened Due to Crash Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 153
Mileage: 226958 km
Time Indication: 0
Date: 2021.10.02
Time: 14:25:48
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 C HW: 4F0 035 223
Component: Amp.-ASK H10 0320
Revision: 31S00001 Serial number: 02710050168883
Coding: 0000101
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000151565
Coding: 0001104
VCID: DEB9063809C9D4EE46F-808B
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 187
Mileage: 225348 km
Time Indication: 0
Date: 2021.08.06
Time: 13:33:00
Freeze Frame:
Voltage: 12.100 V
Temperature: 20.0°C
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0080
Revision: 00-00000
Coding: 0003610
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 187
Mileage: 225349 km
Time Indication: 0
Date: 2021.08.06
Time: 13:33:48
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000111
Shop #: WSC 00164 210 11953
VCID: DDBB013404CFCFF65F5-8088
1 Fault Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 4
Fault Frequency: 3
Reset counter: 153
Mileage: 226952 km
Time Indication: 0
Date: 2021.10.02
Time: 14:25:41
Freeze Frame:
Voltage: 12.94 V
Count: 244
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 L HW: 4F0 035 541 E
Component: TUNER EU/US/RDW H42 0560
Revision: 00000000 Serial number: 352JY057591582
Coding: 0000001
VCID: 2953E5E48007E356E3D-807C
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000146754
Shop #: WSC 00164 210 60251
VCID: 234FF7CCE22B3906A91-8076
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 1510141131
Coding: 344630393135313035432056413031353130313431313331
Shop #: WSC 00000 384 00290
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 187
Mileage: 225349 km
Time Indication: 0
Date: 2021.08.06
Time: 13:33:46
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0003074
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0003074
End ---------------------------------------------------------------------
Saturday,02,October,2021,15:10:08:65217
VIN: WAUZZZ4F16N102173 License Plate: KH55JWE
72
Coding: 0000072
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 226958 km
Time Indication: 0
Date: 2021.10.02
Time: 14:55:48
Freeze Frame:
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00101000
Torque: 158.6 Nm
Torque: 0.0 Nm
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 226958 km
Time Indication: 0
Date: 2021.10.02
Time: 14:55:48
Freeze Frame:
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00101000
Torque: 158.6 Nm
Torque: 0.0 Nm
P1847 - 000 -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 255
Mileage: 226958 km
Time Indication: 0
Date: 2021.10.02
Time: 14:55:48
Freeze Frame:
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00101000
Torque: 158.6 Nm
Bin. Bits: 00000100
P1641 - 000 -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 226958 km
Time Indication: 0
Date: 2021.10.02
Time: 14:55:53
Freeze Frame:
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 00101000
Temperature: 81.9°C
(no units): 0.0
Readiness: 0 0 1 1 1
Coding: 0020855
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 153
Mileage: 226958 km
Time Indication: 0
Date: 2021.10.02
Time: 14:43:44
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0080
Hex Value: 0x0013
Hex Value: 0x1699
Hex Value: 0x00FF
Coding: 0000145
Coding: 0001002
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 187
Mileage: 225349 km
Time Indication: 0
Date: 2021.08.06
Time: 13:34:38
Coding: 0001300
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 235
Mileage: 220027 km
Time Indication: 0
Date: 2021.02.06
Time: 11:29:11
Coding: 0000101
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
Address 15: Airbags
Cannot be reached
Coding: 0102042
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 235
Mileage: 220027 km
Time Indication: 0
Date: 2021.02.06
Time: 11:29:06
Coding: 2308443
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 153
Mileage: 226958 km
Time Indication: 0
Date: 2021.10.02
Time: 14:25:43
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 226958 km
Time Indication: 0
Date: 2021.10.02
Time: 14:25:42
Revision: 00-00000
Coding: 0003610
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 187
Mileage: 225349 km
Time Indication: 0
Date: 2021.08.06
Time: 13:33:48
Coding: 0000763
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 187
Mileage: 225349 km
Time Indication: 0
Date: 2021.08.06
Time: 13:33:52
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 153
Mileage: 226958 km
Time Indication: 0
Date: 2021.10.02
Time: 14:25:48
Coding: 0000101
Coding: 0001104
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 187
Mileage: 225348 km
Time Indication: 0
Date: 2021.08.06
Time: 13:33:00
Freeze Frame:
Voltage: 12.100 V
Temperature: 20.0°C
Revision: 00-00000
Coding: 0003610
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 187
Mileage: 225349 km
Time Indication: 0
Date: 2021.08.06
Time: 13:33:48
Revision: C63C0030
Coding: 0000111
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 153
Mileage: 226952 km
Time Indication: 0
Date: 2021.10.02
Time: 14:25:41
Freeze Frame:
Voltage: 12.94 V
Count: 244
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 187
Mileage: 225349 km
Time Indication: 0
Date: 2021.08.06
Time: 13:33:46
Coding: 0003074
Coding: 0003074
