Hi All,
Just so you know that A6 C8 is quite air tight. This is designed to keep the car isolated from external sounds and insulated from external temperature. One of the down sides of this air tightness is requirement to use more force when closing door especially the front doors. At some point I thought that my A6 driver door was not aligned anymore as it required more force to be used when closing especially after drive.
If you experienced similar issue with your front doors and you are suspecting door misalignment please try to close the door with window half full or completely down before you call your mechanic. If the door is misaligned the problem will persists if the door closes much easier this means air tightness / air trap door closure effect.
Enjoy your A6
Enjoy your A6
