  2. Dismiss Notice
A5 B9 sportsback tyre pressures??
Bobster68 Nov 8, 2019
  1. Bobster68
    Bobster68 Registered User
    20
    Hi all ...im confused as to correct tyre pressures on door decal shows what should be according to loads and size of tyre.
    Mine are stock bridgestone potenza s001 255 35 R19...ive put 39psi front ...36psi rear as it says on door...but dont feel right...what is M+S on the decal next to tyre size..thanks!!
  2. Avatar
    snack-media
    Advertisement
  3. Audidi
    Audidi Useful idiot
    266
    218
    43
    The 2019 A5 sport back manual has 32 psi front and rear for normal loads on 255/35 R19 (2-3 people)
  4. Bobster68
    20
    Thanks! Mine is auto. Dunno if it would make any diff??..i think 36psi or 33psi sounds ok but be good to know what pressures a5 drivers are using.
  5. S32B
    S32B Registered User
    6,484
    7,542
    Isn't the M+S marking for all season/winter tyres?
    With the 'normal' tyres I found that if I use the recommended 2 people setting the middle 2 channels of the tyre wear down faster than the outer edge! I've just put 2 new fronts on mine this week which were down to 2-3mm after just under 7,000 mile :blink: (I do a lot of stop/start trips so that doesn't help) the backs are still on 5.5mm. When I get the chance I'm going to check/drop the new ones a couple of psi below the recommended setting, 75% of journeys I'm in the car on my own anyway.
    You can also use the comfort setting, but you need to keep the car in comfort mode if you do! That's the one with the information/book symbol next to it.
    PS: Mine are the 18's and recommended for 2 passengers is 35psi f/32psi r and for the comfort mode is 30psi f/28psi r....so I think a happy medium for me would be 32psi f/30psi r.
    After less than 7,000:
    The new meat:
    The outer edge difference where the coloured lines are was a shock!
    Feels a lot more planted to the road now when pulling away from lights/junctions :thumbs up: especially since it hasn't stopped raining since I had them fitted! :D
  6. Bobster68
    20
    Thanks! S32B..yep i will drop mine to 33f 36r as mine are 19inch....current 39f car was allover the wet road last nite with heavy rain!...
  7. S32B
    6,484
    7,542
    Front should be higher than rears!
  8. cuke2u
    cuke2u Well-Known Member
    12,914
    5,244
    Yup, weight of the engine....
