NickA5owner
I Have a 2015 (64) A5 3.0 V6 TDi sportsback. Having some intermittent issues with vehicle starting. 67k millage it’s well serviced ive had it from new.
Sometimes put key in ignition, foot on break and all doors closed. press key in to start vehicle and will not turn over. No electrical signal being sent to say start car. When this happens the brake pedal is rock hard there is no movement in the pedal as you would usually expect to see.
Normally to over-come this issue. I remove the key and Re-insert the key press brake again and will fire up. But today 5 times I tried and won’t start. Vehicle in in park, hand brake on but brake pedal is hard and up fully with no movement. Even tried getting out the car, lock doors / unlock and sit inside and try again to no avail.
Called the AA out but by time her arrived I tried starting it again and just fired up 1st time. The break pedal was hard at this time but as vehicle fired up the pedal then pressed down and was functioning as normal. (some negative movement)
No warning lights on dash when this happens or unusual symptoms apart from the firm for brake pedal when fails to start.
Nothing was showing on AA’s dynostic he ran there were no markers on his software. Vehicle is now running / starting fine. Until next time...........
Seen utube videos showing similar issues out there but nobody with any solutions..
Any advise is appreciated. TIA
