A4 bfb replacement engine
St53daw
Just asking for a friend , he's looking to change the engine due to timing belt failure , and is asking if there's another engine code he could use instead of the bfb engine , are most interchangeable or would it need same
Engine code putting in !!
anything pretty much straight swap for the old one basically
Tia guys
Much appreciation
Steve
QuattroCalum
What damage has been done? If the pistons haven't been damaged (ie just valves bent) you could just fit another head.
St53daw
He's not stripped it yet , but was thinking of just swapping it out for another complete unit
QuattroCalum
Personally I would take the head off first, nothing to lose, everything to gain. If there's no piston damage you're laughing.
