kip1986
- Joined
- Jul 5, 2017
- Messages
- 6
- Reaction score
- 4
- Points
- 3
Hi All,
Hopefully posting this in the right place - I've been using OBDeleven rather than VCDS.
I've recently fitted a detachable towbar to my car. The nuts and bolts bit of the job was surprisingly easy and the wiring adaptions wasn't too bad either.
I've tried to do the coding with OBDeleven. Whilst some of it has gone ok I cant find some of the long coding or adaptions that the instructions say to change and as such I've got Pre-sense and lane assist warnings when I start the car.
In the central electrics module - 09 - I've activated the control module in coding but the instructions say "Adaptation -10
Adaptation channel:
networking trailer connection device -> installed"
I can't find that anywhere!
In the Front sensor module - A5 - I need to change the coding for "trailer electrics" in the coding. I can't spot it in the list anywhere!
Can anyone help? Can you point me in the right direction, or if you know the bytes and bits to change let me know, or even if it can't be done in OBDeleven, point me in the direction of someone with VCDS that I could use in exchange for a few beers?
Thanks!
Adaptation channel:
Thanks!
