  2. Dismiss Notice
A4/B9 sedan (typ 8W) rear bumper removal
andy0912 Nov 10, 2019
  1. andy0912
    andy0912 New Member
    Hi all, would someone please send help in removing the rear bumper?
    One of the parking sensor went loose and dropped partially inward. I would like to put it back in place so I suspect this need to be done with the rear bumper taken down... Or is there an easier way to achieve it?
    Thanks!
  2. Avatar
    snack-media
    Advertisement
  3. rasA4
    rasA4 Four Rings Mafia Specialist TFSI Owners Group S-line owners group Team Scuba S tronic saloon quattro Audi A4
    3,759
    298
    remove the rear lights, once you have removed them you will see a plastic pin to pull out, you should also see some bolts,
    then remove boot sill trim, lever straight up you should see some holes for more bolts
    also there are a load of screws in each rear wheel arch liner near the bumper remover
    i think there might be some under the bumper cant remember
    be sure to use a piece of card and pop the bolts/screws and mark them so it will be easier when you reassemble
