A4 B9 LED drl and turn signal not working after coding tweaks
audifan998
Hello there,i tried to code lane assist and high beam assistant.I did not save the autoscan on vcds.I reverted those bits below but my drls and turn signals are not working.I have LED headlights.Can i somewhere get or buy stock values for my car?If someone can help or post a scan of theirs LED a4 i would appreciate.Below i will put what i treid to change,and will post an current autoscan.Thanks
Unit 09
Coding
Byte 5, activate Bit 0, Bit 5 and Bit 6
Unit A5
Coding
Byte 21, activate Bit 5
A5 - Frt Sens. Drv. Assist
HC>Active | Byte 16>Bit 7
EFP>Active | Byte 12>Bit 3
17 - Dash Board EDIT:
Lane Assistant>Active | Byte 4>Bit 6
09 - Central Electrics
Heading Control Config>heading_control | Byte 35>Bit 0
44 - Steering Assistance
Heading Control Assistant>Active | Byte 2>Bit 7
AUTOSCAN
Thursday,24,October,2019,15:48:24:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WAUZZZF42HA013539 License Plate:
Chassis Type F4-AU49 (4M1)
Scan: 01 02 03 08 09 15 16 17 19 42 44 46 47 52 5F 81 A5 AC BB BC
VIN: WAUZZZF42HA013539 Mileage: 147514km-91660miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: INTERFACE NOT COMPATIBLE
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
81-Gear Shift -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
AC-Reductant Control -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-DEUA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 T HW: 04L 907 309 L
Component: R4 2.0l TDI H34 1981
Revision: B1H34---
Coding: 0A254032230405083400
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TDI01104L906026T 001005
ROD: EV_ECM20TDI01104L906026FS.rod
VCID: 3B7581EDB265A792C0-806E
1 Fault Found:
23755 - Body Control Module (Central Electric)
U0140 00 [039] - No Communications
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 147516 km
Date: 2021.01.13
Time: 17:35:39
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 19 °C
Intake air temperature: 22 °C
Ambient air pressure: 950 mbar
Voltage terminal 30: 12.020 V
Unlearning counter according OBD: 40
Limitation: accelerator pedal: 0.0 Nm
Cruise Control System (CCS): status-Bits 0-7: 2
selected gear-Bits 0-7: 0
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W0 927 155 F HW: 0CK 927 156 AA
Component: 0CK 20TDI RdW H04 0004
Revision: --H04--- Serial number: 0000002038
Coding: 000001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDL382021 002023
ROD: EV_TCMDL382021_AU48.rod
VCID: 428BFC09D58FD65A83-8016
Manual Transmission Fluid Pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP 002 0572
Serial number: 75117071160146000332
No fault code found.
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 E HW: 8W0 907 379 J
Component: ESP9 Plus H06 0593
Coding: 04AA1C9910A30A9915A3489400865292E6A59220380850A812004A4967A549
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ESP9BOSCHAU49X 012014
ROD: EV_ESP9BOSCHAU49X_012.rod
VCID: 479DED1DFEADF37254-8012
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8W0 820 043 P HW: 8W0 820 043 P
Component: Klima Zone 1 H40 0071
Coding: 141800295140000500000100080000000000000000000000000000000000
Shop #: WSC 06325 790 00001
ASAM Dataset: EV_AirCondiBHTCAU491 001013
ROD: EV_AirCondiBHTCAU491.rod
VCID: 408FF601DB83C44A95-8014
Fresh Air Blower Front:
Subsystem 1 - Part No SW: 4M1 820 021 HW: 4M1 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000000886516
Relative humidity sensor in fresh air intake duct:
Subsystem 2 - Part No SW: 4G0 907 658 B HW: 4G0 907 658 B
Component: Humidity_Sens H01 0005
Serial number: AE188C2800PAG0FSA002
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 BF HW: 8W0 907 063 BF
Component: BCM1 MLBevo H13 0248
Coding: 07501143E11800CD01445119182D00B9100B110800000000000000000000000000000000000000
ASAM Dataset: EV_BCM1BOSCHAU736 016006
ROD: EV_BCM1BOSCHAU736_016.rod
VCID: 000F36019B03044AD5-8054
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8W1 955 119 HW: 8V1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 160504 043 0813
Serial number: 894353?0301612504428
Coding: 5BC7F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 555 HW: 81A 955 555
Component: G397_RLFSS H06 0001
Serial number: 20018387X81A95555500
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 24 03 2016 00293401
Interior Light Module:
Subsystem 4 - Part No SW: 8W0 947 135 D HW: 8W0 947 135
Component: J528-Dachele H13 0082
Serial number: B10152957
Convenience And Driver Assist Operating Unit:
Subsystem 5 - Part No SW: 8W0 925 301 AT HW: 8W0 925 301 AT
Component: SL-B9/Q5NF H16 0010
Serial number: 2616000023791005
Coding: 000000
4 Faults Found:
66678 - Databus
U1123 00 [009] - Received Error Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 231
Mileage: 147516 km
Date: 2021.01.13
Time: 17:38:10
average_Voltage_terminals: 14.90 V
Outside air temperature sensor-Resistance: 2.56 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 3.00 °C
interior_temperature: 7.00 °C
Vehicle speed: 0.00 km/h
Terminal control-Terminal 75 status: On
Terminal control-Terminal 15 status signal: On
Terminal control-Terminal 15 via CAN: On
Terminal control-Term 75: qualification: OFF
66679 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 231
Mileage: 147516 km
Date: 2021.01.13
Time: 17:38:10
66963 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 231
Mileage: 147516 km
Date: 2021.01.13
Time: 17:38:10
66964 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 231
Mileage: 147516 km
Date: 2021.01.13
Time: 17:38:10
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 HW: 8W0 959 655
Component: Airbag10.44 H72 0086
Serial number: 003M600441YV
Coding: AACCF0C00C800000585400F3C00C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
VCID: 06032019B9272A7AEF-8052
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 442 060 305 16
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y00C31DE13F2B0FH
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 442 060 305 16
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y00C31DE13F154DD
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 604 16
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700C31CCE9B4246R
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 442 0B2 604 16
Component: SideSensor_Pr 1C7 0148
Serial number: 3527700C31CCE9B4528V
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 442 0C0 405 16
Component: FrontSensor_D 1C5 014A
Serial number: 3557500C320BEED0732K
Coding: 2D2D2D
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 442 0C0 405 16
Component: FrontSensor_P 1C5 014A
Serial number: 3567500C320BEED4638U
Coding: 2D2D2D
Pedestrian Protection Center:
Subsystem 7 - Part No SW: ----------- HW: 442 0C0 405 16
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500B120BEED0619D
Coding: 2D2D2D
Pedestrian Protection Driver 2:
Subsystem 8 - Part No SW: ----------- HW: 442 432 704 16
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00BD1F4FCB2355$
Coding: 2D2D2D
Pedestrian Protection Passenger 2:
Subsystem 9 - Part No SW: ----------- HW: 442 432 704 16
Component: PedPSensor_P2 256 0887
Serial number: I0N9M00BD1F4FCB412E3
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 HM HW: 4M0 907 129 HM
Component: Lenks.Modul H11 0009
ASAM Dataset: EV_SMLSKLOAU736 006008
ROD: EV_SMLSKLOAU736_006.rod
VCID: 020B3C09950F165AC3-8056
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 741 A HW: 8W5 920 741 A
Component: MMA4M17DIERW H06 0363
Revision: 0339v7 Serial number: PY5FNJH5S
Coding: 04A450C028800008002028201000000000000000
Shop #: WSC 12345 768 00001
ASAM Dataset: EV_DashBoardAU736 001022
ROD: EV_DashBoardAU736_AU49.rod
VCID: 3C7782F1B76BA0AAC9-8068
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4M1 907 468 C HW: 4M1 907 468 A
Component: Gateway H15 0097
Revision: 4R030001 Serial number: 0144R00E616513
Coding: 0301000100000E404107000000590012C8100007000000000100000000000000
ASAM Dataset: EV_GatewCONTIAU736 002060
ROD: EV_GatewCONTIAU736_002_AU49.rod
VCID: 377D9DDD8E4D83F224-8062
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 4M0 951 523 A HW: 4M0 951 523 A
Component: J453 MFL H06 0002
Serial number: 20160512203851 02535
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Component: J367-BDMHella H10 9070
Serial number: 7006010404
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 8W0 959 593 G HW: 8W0 959 593
Component: TSG FS 005 0052
Serial number: 0000200712787
Coding: 005D0B204000000000001080
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
VCID: 4E93D83911D7223A17-801A
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 8W0 909 144 F HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0407
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 002015
ROD: EV_EPSZFAU49X_002.rod
Address 46: Central Conv.
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
Address 47: Sound System (J525) Labels:* None
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAGJA000GDU
Coding: 0194010800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI_AU49.rod
VCID: 76E350D9C9C73AFAFF-8022
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 8W0 959 592 G HW: 8W0 959 592
Component: TSG BFS 005 0052
Serial number: 0000200729145
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
VCID: 4D91DF351CD119226E-8018
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 8W0 035 840 A HW: 8W0 035 840 A
Component: MU-S--ER 710 0740
Serial number:
Coding: 019401000000000013110002000A00002F0001E40170010002
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_AU49.rod
VCID: 3467AAD19F3B68EA01-8060
Display unit 1 for multimedia system:
Subsystem 1 - Part No SW: 8W0 919 604 HW: 8W0 919 604
Component: AU49x_DU_STD H40 0008
Serial number: AUZ8Z9GBG00XPF
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8W0 919 614 M HW: 8W0 919 614 M
Component: ControlUnit_B H22 0134
Serial number: APVAK104051600030057
2 Faults Found:
7177 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 16
Mileage: 146954 km
Date: 2021.01.06
Time: 21:26:38
Voltage terminal 30: 13.0 V
BAP-BAP_Function_ID: 02
7178 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 219
Mileage: 146954 km
Date: 2021.01.06
Time: 21:26:38
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 E HW: 8W1 713 041 E
Component: GSM-LL H08 0068
Revision: 0L0D5012 Serial number: 20160506003586
ASAM Dataset: EV_GSMWaehlZFAU736 001013
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 356197D5944171E236-8060
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W0 907 217 B HW: 8W0 907 217
Component: BVS H14 0042
Coding: 0404090100000401022000A0850000FC00F0C0200000
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026
ROD: EV_BVSMLBevKOSTAAU736.rod
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 HW: 4M0 907 355
Component: SCR-Stg-G3H10 0003
ASAM Dataset: EV_RDCMINERGAU736 005009
ROD: EV_RDCMINERGAU736.rod
VCID: 6ED378B9B197023A37-803A
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 8W0 959 595 G HW: 8W0 959 595
Component: TSG HFS 005 0052
Serial number: 0000201879907
Coding: 000D09200000000000001080
ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005
ROD: EV_DCU2RearDriveMAXHCONT.rod
VCID: 50AFC6410BE334CA05-8004
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 005 0052
Serial number: 0000201879868
ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005
ROD: EV_DCU2RearPasseMAXHCONT.rod
