  2. Dismiss Notice
A4 B7 scuttle cover
MeteorT7 Nov 14, 2020
  1. MeteorT7
    MeteorT7 New Member
    Hi
    I have just fitted a scuttle cover to my A4 B7 Avant but still seem to be missing a cover, as shown in the picture, can anyone please advise a part number or name of the missing part? It would cover the ECU.
    Many thanks
  2. Avatar
    snack-media
    Advertisement
  3. redVENGEANCE
    redVENGEANCE Registered User
    41
    12
    Are these oem or aftermarket?
    Sent from my SM-G950F using Tapatalk
  4. MeteorT7
    MeteorT7 New Member
    Hi
    As far as I know they are genuine Audi parts.
    Mark
  5. redVENGEANCE
    41
    12
    Mine has none. Surprised they dont come as standard.
  6. joinerman
    joinerman Registered User
    15,199
    644
    Egay
  7. Pie-eyedpiper
    Pie-eyedpiper Registered User
    805
    332
    Mine doesn't have a cover over the ECU either. I've never seen one that does.
    I believe scuttle covers were standard on B6s, but not B7s.
  8. joinerman
    15,199
    644
    My B6 didn't have the cover when i got it, got all the parts off the bay, all genuine parts as well, all most certain B6 bits would fit a B7, basically same car isn't it.
  9. norad97
    norad97 Registered User
    723
    148
    43
    You have to buy that cover as well. I'm sure there is parts list on this forum.
  10. I'm Just Rob.
    I'm Just Rob. Moderating or something, Staff Member Moderator Gold Supporter VCDS Map User
    16,162
    7,193
    I dont have it either , also keep in mind a lot of B7's never had the full length cover to start with, my old bus never came with it factory fitment.
  11. I'm Just Rob.
    16,162
    7,193
    Also the desiel has a difference ecu box which is why yours doesn't fit the same as the my tfsi item.
  12. Avatar
    snack-media
    Advertisement
  13. I'm Just Rob.
    16,162
    7,193
    more importanly audi dont acctually list a cover for the ecu end, probably why no body else has one fitted either, well not as an OE part that is.
  14. Chrismawa
    Chrismawa Registered User
    669
    127
    43
    How much are the covers from Audi?
  15. Pie-eyedpiper
    805
    332
    What part is 38 then Rob?
  16. tr7
    tr7 Registered User
    413
    124
    43
    I'm Just Rob. likes this.
  17. redVENGEANCE
    41
    12
  18. I'm Just Rob.
    16,162
    7,193
    only 3 parts involved .
    3B which is the pollen filter box cover , fitted as standard to all buses.
    the full length plenum cover is a single part and you'll need the battery cover section aswell as that is a single part.
    this picture highlights the issues the original op raised.
    the ECU box shape and size designs differ from variants hence why the final fit differs.
  19. norad97
    723
    148
    43
    Well I forgot I did not buy the extra cover when I purchased mine, as Rob states the TFSI has a different ECU box, why...
    That's Audi. I guess the TFSI ECU cover wont fit the oil burner box?
  20. I'm Just Rob.
    16,162
    7,193
    Don't forget that when you change to the full length cover with battery panel the original pollen cover (3B) is not used .
  21. norad97
    723
    148
    43
    Maybe you could look at using the old pollen filter cover and modding it to fill the gap, just a thought.
  22. I'm Just Rob.
    16,162
    7,193
    now that's a good idea Richard, i'd have a go at that had I not binned my cover recently...:sadlike:
  23. norad97
    723
    148
    43
    I still have mine, but my scuttle panel fits like yours so its looks fine.
    But he could try to make a cover from his old pollen fillter cover.
  24. antwan64og
    antwan64og Registered User
    1,136
    298
    Related to this are there drain holes in the top scuttle area that need periodically cleaning?
    I can’t see any and heavy rain seems to build up in there
  25. joinerman
    15,199
    644
    Underneath the battery, there's two rubber bungs, take them out and throw them away.
  26. antwan64og
    1,136
    298
    Thanks, I’ll look tomorrow. I was considering taking a drill to her.....
  27. joinerman
    15,199
    644
    If you have small hands and a bit of a contortionist you can get them out without removing the battery.
