Hi all,
a few months ago i finally got around to replacing my EGR unit. I went for a replacement rather than just a clean due to the miles the car has done now. Everything went well and the codes cleared and MIL light went off the dash. With the new unit it began to run a bit lumpy at idle and smoke a lot when not under load. There were a few episodes of what i could only describe as the engine cutting out until the light came back on the dash again. I hooked up VCDS and its showing a egr position sensor fault now, on a new unit which has been on the car only a couple of thousand miles. As it happens the car is running great with the light on, i'm guessing the EGR is currently doing nothing though.
Have i just been unlucky with a new part and its failed, or are there any clues on how to fix this ?
I also have a secondary question, on VCDS my EGR value was set at 128. I was also unable to change this as it appeared to be locked. the only screenshots i have seen of these values tend to be in the thousands. Does anyone know what the 'default' EGR value should be ?
thanks
thanks
