  2. Dismiss Notice
A4 B5 V6 2.5TD fuel pump
cammy kyle Apr 23, 2019
  1. cammy kyle
    cammy kyle New Member
    car gets starved of diesel when approx half tank. Have been told that there will be 2 lift pumps in tank Is this correct ? If so which one is likely to be the problem
  2. Avatar
    snack-media
    Advertisement
  3. SwissairMD11
    SwissairMD11 New Member
    That is weird, my 2.5 TDI had only 1 fuel pump that whas the diesel pump it self a VP44. It's just 1 tank 62L, what you describe is more like a problem for a B6 or an A6 C5/6
  4. Mourad
    Mourad New Member
    Hi,
    If it's Quattro then it has 2 pumps, I had the exact same issue, I installed a boost pump in the driver side tank as I had a cracked fuel tube, to keep filling the passenger side tank, for about a month or so, till I got an original tube from a used car.
    By checking the tubes in passenger side you'll probably fix it.
